Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: PC 7424xp
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    1,889
    Re: PC 7424xp
    Quote Originally Posted by MarkD51 View Post
    In the few years I've been here, and reading pretty much all that has been written about the PC7424XP, I cannot recall reading anything about such.
    But that doesn't mean your questions and thoughts aren't valid ones that do not hold some serious consideration.
    I've never popped open my own PC D/A, but one day may. But I have once popped open my Baby Griots 3" D/A the second time out, of what I felt was some more additional noise, and rough running from the first time I used it.
    And yep, what I found, was two Motor Brushes cracked in half, and was lucky that it came with an additional spare pair of brushes. It looked like they may have been damaged upon installation at the factory, that they came partially out when closing and buttoning up the two main housing halves.
    But to get onto what else I noticed upon opening the unit, was a Pinion Gear Drive Set that was as dry as a bone, with a lot of grease just slung out of the way of the Gears. No doubt caused by centrifugal force and heat, and while there was plenty of grease inside the case, it appeared none of it was doing the gears any good as far as protection, and perhaps as well the noise levels of operation when running.
    I entirely removed all of the factory grease, questioning its quality, as this was an unknown, and replaced this lubricating grease with a like amount of full synthetic Permatex Super Lube Grease fortified with PTFE.
    (in truth, the factory grease may have possibly had similar qualities to Super Lube, but like I said, this was an uncertainty)
    The machine worked much better, seen the somewhat design flaw of how the brushes could pop out while re-assembling, and addressed that issue. The machine then ran smooth, and suspect the major issue was the cracked brushes. The re-lube certainly didn't hurt.
    I would suspect the Porter Cable D/A has a similar basic construction inside like the Griots in regards to the Gear Set Design and mechanics of operation.
    Thus with all this being said, and if a person feels they have both the mechanical, and electrical expertise to open up the Porter Cable machine to inspect, and to possibly check things like lubricants, and possibly re-lube, I myself see no harm, and in fact may help the machine operate more smoothly, run cooler due to greases being where they should be, and by inspection, possibly finding other assembly snafus which could head off premature failure.
    I would think too, that like the Griots 3" DA, the PC DA may also eventually "fling" it's protecting lubricants around inside the case, and again the gears would be getting little to none of the lubricant's protection benefits.
    I also think that with such machines, it is also not wise to leave such machines to bake away in really hot garages, or sheds during summer months, that heat may cause lubricants to soften, and then move away from the gears possibly.
    Hope my ideas have some merit.
    Merit? Hell, now this is one of the best posts I've ever read.
    Excellent post, Mark!! I do the same thing with every power tool I buy and think "hey, this thing shouldn't run like this......"
    Apart it comes, and I have certainly found similar results as yours on more than one tool.
    I like the way you think, bud.
    Senior Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    2,262
    Re: PC 7424xp
    Well, I did take a different path than what most people would've done with a machine that was thought to be bad, and had an issue.
    That 3" Baby Griots DA I did not buy from Griots, AG, or any other authorized dealer, but from a seller on Ebay for the small sum of $63. But it was a brand spanking new machine, one could definitely tell it had never been used prior to my acquisition.
    I doubt I had more than an hour's use on this machine prior to opening it up to inspect.
    But none the less, I did contact Griots Garage after the repair, posed the questions of return and what their policies were, and they told me that it didn't matter where it was purchased, or no bill of sale, that they would accept the return, and replace the machine free of charge.
    Now that's what I call a great company!
    Also as well, when a unit of whatever brand is within its warrantee period, and perhaps even after that warrantee has expired, and was purchased from AutoGeek-Autopia, the Unit hypothetically failed not due to user error-damage, one might be wisest, and I would advise-suggest first contacting these people first before any further actions are taken, and/or executing a self repair.
    I'd suspect there are accounts-stories of Autogeek as well going beyond their commitments, and replacing a machine that failed, and perhaps too even past the manufacturer's warrantee, in that they want their customers happy and satisfied.
    Had my machine that failed or thought to work strangely been a Rupes, or a Flex purchased from AG, costing multiple times what the baby Griots DA cost, I'd surely be contacting AG first before trying to initiate repairs myself.
  3. #13
    Oct 2012
    Sheboygan Wisconsin
    2,262
    Re: PC 7424xp
    The major problem I recall with my 3" Griots DA was a Brush Set that is simply retained by slotted depressions on either case half.
    But when installing the new set of Motor Brushes into one half of the Plastic Housing Case, and getting ready to re-assemble the two Case Halves it was easily recognized that due to the spring pressure on the Brushes, they had a quite easy propensity to not stay put in their assigned small depression slots.
    With some thought, I then simply used two small strips of Electrical Tape to better secure-retain them in the one housing half, so that they would not lift out as the case halves were re-joined together.
    This did the trick!
    After complete re-assembly, I then finally manually rotated-turned the motor via the Backing Plate by hand to "run in" and initially seat the Brushes for a few minute's time before electricity was applied to test.
  4. #14
    Senior Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    4,090
    Re: PC 7424xp
    Mark, have you ever removed the plastic head cover from a 1st gen PC 7424?
  5. #15
    Oct 2012
    Sheboygan Wisconsin
    2,262
    Re: PC 7424xp
    Gee, no I haven't. But I have remembered some threads about the PC, perhaps it was the newer PC7424XP DA, in that without using a Stick Handle, or if choosing not to use a handle at all as some do, that some, (perhaps it was Mike Phillips himself) stated that one should secure the Plastic Head Cover with Bolts-Washers, that this front Plastic Cover can pop off. Thus is appears it then clips on.
    Never having owned an earlier 7424 machine, I am not sure they are identical in design? I would maybe guess yes, but again not sure. On either machine, they may just simply clip on?
    With that said, it is likely that one would maybe need something like a small Jeweler's Screwdriver to gently and carefully pry the Front Case from the Machine, and guessing this part probably has to come off first before further disassembly can commence.
    With a little diligent online searching, you may be able to find an exploded view of the PC7424, or possibly even a youtube vid, and this may aid you.
    Hope this helps.
  6. #16
    May 2013
    Rochester Hills, Mi
    4,090
    Re: PC 7424xp
    Thank you, Mark!
    It doesn't want to come off, and I was wondering of there is a trick to it, before I go Ravishing Rick Rude on the thing.
  7. #17
    Oct 2012
    Sheboygan Wisconsin
    2,262
    Re: PC 7424xp
    Thank you, Mark!
    I get the impression with the PC DA's, that you flip it belly side up, that you are now looking at its underside bottom, that there the front cover is sort of "split", that at these areas you slightly spread the cover with some small prying tools (screwdriver) then slip the cover off forward.
  8. #18
    May 2013
    Rochester Hills, Mi
    4,090
    Re: PC 7424xp
    Sounds good! I'll give it a shot.
  9. #19
    Aug 2010
    Fairmont, MN
    3,040
  1. More cut from 7424XP
    By ChrisB2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 09-18-2015, 06:42 AM
  2. After using PC 7424xp
    By Jeepster19 in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-10-2013, 02:25 PM
» January 2018
28 29 30 31 123
