08-24-2007, 06:14 AM
|  | Senior Member | | Join Date: May 2007 Location: Winter Springs, FL
| | | Observations w/ 106, questions. Ok, so I used 106 on my hood yesterday. Just a test panel, because I wanted to know what to expect for the full detail on sat. I clayed the hood, and then started polishing 1/4 of the hood with the 106, and a white 5.5in pad.
It worked in very easy, It did not dry out early at all. I made 4 passes front to back, mixed with 2 passes of side to side. Very slow, because the hood has the most visible swirls. The polish looked just about broken down, so I let of the pressure and started speeding up the PC. I noticed that the polish became very tacky. My pad skipped when I tryed to gloss the polish.
> Does this mean that the polish was broken down??
> Or should I have given it more time??
It was also very hard to remove, even with a indigo towel and 50/50 alcohol/ water mix. Is all this normal? It was still a dream to use, other than the hard to remove part.
Thanks for your help, Mike |
08-24-2007, 08:28 AM
| | BUMP... wow this makes me sad  , my first bump ever on AG... |
08-24-2007, 09:16 AM
|  | Senior Member | | Join Date: Oct 2006 Location: Alberta, Canada
| | | I'm sure what you experienced all Menzerna users have experienced. I know I have. The thing with 106FF is that it's very picky, I'm sure you noticed that it also seemed to gum up your pad as well? Well that happens to me, but what I found that helps is the heat from the rotary. I tends to want to hop and skip a bit but once you get pat the hopping and skipping your good to go as for the removal I've always used an alcohol wipe down and it removes it no problem, mind you I sometimes have to give it a few sprays and let it sit for a bit then wipe it. When I say let it sit for a bit, no more then a minit. Hope this helps, the draw back with Menzerna is that (in my opinion) it's very temperature dependent. When the temperature is right it will work incredibly well but if the temperature, humidity or surrounding environment is not that great Menzerna tends to act up like the way you described. I've had this happened a few times now. Doesn’t bother me, I just keep going and always love the results. |
08-24-2007, 11:33 AM
| | Thanks Nica, I checked the results in the sun this morning, and it looks incredible. All the swirls are gone, and the paint is very glossy. I will try your suggestion to let it sit for a minute. Then wipe off. No gumming on the pad, but I was using a PC, and I only did one panel. Quote: |
Posted my Nica- I tends to want to hop and skip a bit but once you get pat the hopping and skipping your good to go as for the removal | So, when it is tacky it is not fully broken down?
Thanks for the help. |
08-24-2007, 11:40 AM
| | Member | | Join Date: Jun 2007 Location: Raleigh, NC
| | | Good info here, I'll be working with 106 soon myself.
__________________ Cars to be detailed: 2006 Pontiac GTO, Spice Red Metallic, 6-speed, 17" wheels - minor swirls, overall good condition 2006 Honda Accord coupe, Black Pearl, 5-speed - Paint in bad shape, tons of swirls and water marks, sat on a dealer's lot for nearly 1 year
1997 Subaru Legacy GT wagon, Red, automatic - Crappy re-paint to begin with, much improved, may need XMT #4 on the roof |
08-24-2007, 12:19 PM
| | Quote: |
Originally Posted by A1monky So, when it is tacky it is not fully broken down? | Hard to say, some times if it's acting up it will do this and the polish wont even do anything for you. But when it's fully brokend down it will look nice and clear just like all the other polishes. You should see nice paterns too as your polishing, if it's drying up quickly either you need to prime the pad, I prime my pad with the product it's self. Another thing I've noticed is that once the foam pad is saturated with product, not gummed, it seems to work even better. Before, when I saw the pad get all saturated I would go and clean it and then come back but one day I just kept going and loved the results. Seems that the when the pad is all saturated you use less product and I feel that I get really nice results. Oh and sometimes you will see chunks of polish fly out, don't worry about it just keep going...again this is just me and my experiance with Menzerna.
When it's "tacky" that's a sign that it's acting up but ignore it and continue using it, it seems (again just me) that it corrects it's self. I use the rotary and when Menzerna starts to act up a bit on me I just keep going and it seems to correct it's self. Like I said I think Menzerna must like the heat from the rotary or something because as I keep going it gets better and better...but that could just be me.
Well I hope this helps a little and let me know what you find out from your own dealings with Menzerna. Always enjoy reading the experiance, weather good or bad or better yet what you experimented with and found out, with Menzerna.
The Power Gloss by far the best Compound I've used...just amazing compound can't say enough about it. |
08-24-2007, 12:29 PM
|  | Senior Member | | Join Date: Mar 2007 Location: Windsor, Ontario
| | | Maybe it's designed more for a rotary than a pc. i only use a rotary and all menz products have worked flawlessly for me.
__________________
2004 Infiniti FX35
08-24-2007, 03:05 PM
| | Quote: |
Originally Posted by Nica When it's "tacky" that's a sign that it's acting up but ignore it and continue using it, it seems (again just me) that it corrects it's self.
Well I hope this helps a little and let me know what you find out from your own dealings with Menzerna. Always enjoy reading the experiance, weather good or bad or better yet what you experimented with and found out, with Menzerna.. | Thanks, tommorow I will work through the tackyness. It was very very very humid yesterday, it gets more humid throughout the day in Orlando. And, I used it at 6pm. Tommorow I will be using it in the morn. that might help. I still loved using it. I just never had a polish behave like that before. It did not dry up at all, and it did not dust alot or throw polish balls. All the swirls are gone with one pass w/ the white pad. Cant ask for more than that.
I have only tryed FP and 106 w/ a PC, but I have found that both work well with the machine.
08-25-2007, 12:04 AM
| | Sounds good, look forward on hearing how it goes and if at all posible looking forward to the pictures
Unfortunetly as great as the Menzerna polish is it's cryptonite is the temperature/humidity, heck I don't even know if sea level elevation effect it for all I know but it is picky. Still love it though and I'll continue to use it...untill I find something better to replace it....so I keep my eyes and ears open to try something new. |
08-26-2007, 03:58 AM
| | I just realized that I can show you how Menzerna should look when it's all borken down, like I said it's just like any other polish but instead of me trying to explain it to you I'll show you.
Picture 1: On this picture I'm basically just spreading Final Polish II with a Menzerna polishing pad. Oh sorry for the lighting.
Picture 2: Still spreading but had increased the speed a bit.
Picture 3: Now running at about 1500rpm and the idea is to break down the polish, remember I mentioned over laping paterns, well here they are.
Picture 4: On this picture you can see the polish just starting to flash, but not quite done yet.
Picture 5: Almost done but not quite, but notice how it seems clear and not at thik as in picture 3.
Picture 6: Now, this one prity much shows the polish completely broken down. See how it looks nice and clear well that's when the polish has completely flashed over and you should be good to remove and inspect the results.
One thing to keep in mind that I'm using the rotary so this process, of the polish braking down, happens fast...some times less then two minuits...but one thing about Menzerna products, well in this case Final Polish II, is that you can work it in for some time because of the oils it has. Others like Power Gloss Compound flash faster and turns to dust.
Oh another thing to note is the size of the working areak, don't take to large of an area, about 2 x 2 is perfect, specially with the PC. The pictures show a reasonable working area but as I kept spreding the polish the area got a bit larger. Well my experiance with the PC was that I couldn't take a large surface areas as compared to the rotary, with the rotary I can stretch it lots but with a PC it's limited...just my experiance.
Well I hope this helps.
|  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
