Quote:
Originally Posted by waldron80 I'm getting the Port Cable 7424 for my B-Day and I would like some feedback about the approach I am taking. Take a look at the pics and let me know what you think. Thanks.
My Approach:
XMT 2 with Orange LC pad
XMT 360 with White LC Pad
XMT 180 with Blue LC pad
Is this too much? Too little?
Should I use XMT 1 instead of 360? Should I use another Sealent instead of the 360? Opinion on XMT 180?
Also keep in mind I'm taking this approach because it is very cost effective.
Regards,
Waldron80  |
I agree, I dont think that XMT 2 will be powerful enough for those swirls. Like budman said you will probably want to step up to Xmt 3. I would do this:
Xmt 3 with medium cut pad.
Xmt 360 light cut pad
WAIT ~20 HOURS FOR SEALANT TO CURE.
Apply wax.
There are some other products you might want to look at, OPT opti seal for example instead of XMT 360, its almost the same thing but I think you might like it more, it is more cost efficient, you get almost 2x more for just 5 more dollars. Also it does not dust. And instead of xmt 180 you could get liquid souveran or spray souveran. Good luck.
