08-08-2007, 11:53 AM
|  | Senior Member | | Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| | | Cleaning Pads during a Detail. What is your technique when your pad gets too dirty to continue on the same detail?
If anyone cleans and keeps the same pad in play, how do you do it? |
08-08-2007, 12:05 PM
|  | Senior Member | | Join Date: Apr 2007
| | I spray them with xmt pad cleaner, and just rinse them with the hose. Put them on the machine, and spin them to they are dry
__________________
Audi Allroad Quattro
VW Jetta 4 TDI
08-08-2007, 12:11 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Northern VA
| | | Clean with Dawn and warm water, spin dry on PC. Then back to work. You have to make sure is 100% dry though. |
08-08-2007, 12:55 PM
|  | Senior Member | | Join Date: Nov 2006 Location: South Florida
| | | Before I start detailing a mix up a bucket of pad soap & water. When a pad gets dirty I just throw it in and get a different pad. When I done with the detail I wash out all the pads. |
08-08-2007, 01:01 PM
|  | Senior Member | | Join Date: Jan 2007 Location: Asheville, NC
| | | Just FYI,
Before all you people that have never tried it before go out and start spinning your pads on a machine to dry them, make sure it is on a lower setting or else the pad is going to fly off and chop your nose off, put your eye out or kill your dog. So be careful when free spinning a pad on a machine because it can fly off at a rapid speed. I've seen it happen.
(That is mostly for the hook and loop pad users. I don't see the edge type system pads having this problem.)
__________________ What if the Hokey Pokey IS what it's all about??? |
08-08-2007, 01:07 PM
| | Quote: |
(That is mostly for the hook and loop pad users. I don't see the edge type system pads having this problem.) | Good point. I keep pressure on the bottom of the pad with my other hand so this doesnt happen.
Pretty sure Jimmie is used the Edge system though. |
08-08-2007, 01:38 PM
|  | Senior Member | | Join Date: Feb 2007 Location: Rockledge, FL
| | | Pad brush and the rotary at like 2000-2200 rpm.
I usually don't detail enough during the one day to need all my pads, so if working with the PC and they get clogged, I'll through them on the rotary and brush them, or just grap another one and stick it on the PC.
__________________
2005 Phantom Black Metallic GTO-M6
Head/Cammed-450rwhp/415rwtq
1/4--12.1 @ 118mph, 1.7 60'
08-08-2007, 01:49 PM
| | Senior Member | | Join Date: Jan 2007 Location: Grand Rapids MI
| | | I spur my foam pads with an old tooth brush after every panel. Once they get to caked that the spur isnt working anymore i wash them out with XMT pad cleaner, rinse, put them back on the machine and spin all the water out. Then i get back to work, its ok if the pad is still a little damp, wont effect anything.
Since i use the edge2K system on my rotary i rarily have to do this and i have multiple pads for my PC. |
08-08-2007, 02:59 PM
|  | Senior Member | | Join Date: Jun 2007 Location: Southern California
| | Quote: |
Originally Posted by pirex I spray them with xmt pad cleaner, and just rinse them with the hose. Put them on the machine, and spin them to they are dry  | I do the same even though I have enough pads just to switch in the middle of a detail. I just hate having to clean all of them at the end of the day, so I clean it as I work. |
08-08-2007, 03:09 PM
| | Quote: |
Originally Posted by blkexcoupe I do the same even though I have enough pads just to switch in the middle of a detail. I just hate having to clean all of them at the end of the day, so I clean it as I work. | That funny, I hate to stop detailing to clean pads. After soaking the clean up real easy at the end of a detail. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
