08-12-2007, 01:55 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Northern VA
| | | I know this is a little late, but thanks for the review budman.
Now I have been using Dawn with warm water to clean my pads. I do it by hand with a brush, then spin dry. Ive got two of everything, so I just grab the other pad if the other one gets gummed up or whatever. Anyways, I found this thread on autopia. I dont think Im allowed to give a link, but the title of it is "CAUTION!! : Dishsoap ruined my pad !!" Now if you go there, youll see a post by me which says I havent had an issue using Dawn. Well, Im going to have to take that back. I guess I never really payed close enough attention. But I do see the edge of my pad starting to disintegrate, crumble, whatever. Also, when I get ready to use my pad the next day, I put it on the PC and spin it, and dust starts coming off. Well I noticed this is actually the pad crumbling up. I dont know if this is from the Dawn, or because I use my pads so often. But I figured I would make you guys aware of it just in case it is the Dawn. Ive since switched over to using Woolite 8:1 or 10:1 to clean them. Better safe then sorry right?
So heres my new method.
Rinse with warm water/ scrub with hands
Spray on Woolite 8:1 or 10:1 (pre treat for 1- 3 min. for tough stains)
Scrub with brush
Rinse thoroughly
Squeeze out water
Spin dry on PC or rotary
Lay pad FACE DOWN on plastic bag or something clean over night
Once dry, store in plastic container.
I find Woolite 8:1 & 10:1 to be more cost efficient, easier to rinse out, and cleans just as well. It should also be gentler on the pads. |
08-12-2007, 04:14 AM
|  | BANNED | | Join Date: Mar 2006 Location: South Australia
| | | Recently I got a 7.5 kg Hoover Boss top loader and instead of using the DP cleaner or laundry liquid, I use wax free car shampoo and boy does it clean the pads back to like new
Plus the velcro backing stays put. I always double rinse them afterwards to make sure their is no residue still inside |
08-12-2007, 07:53 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Southern NH
| | Quote: |
Originally Posted by D&D Auto Detailing Also, when I get ready to use my pad the next day, I put it on the PC and spin it, and dust starts coming off. Well I noticed this is actually the pad crumbling up. I dont know if this is from the Dawn, or because I use my pads so often. But I figured I would make you guys aware of it just in case it is the Dawn. Ive since switched over to using Woolite 8:1 or 10:1 to clean them. Better safe then sorry right? | I thought this was just a little polish left over in the pad that didn't get rinsed well. I'll have to keep an eye on that, thanks. |
08-12-2007, 10:39 AM
|  | Senior Member | | Join Date: Jun 2006 Location: Central Florida
| | I let them soak in a 5 gallon bucket with a little APC for about an hour, then I agitate them with my hands while in the bucket, then I center them on my grit guard in the driveway and hose them off. Then I wring them out, then slap them on my PC on speed 6 for a few seconds, then store them on a towel overnight to let them completely dry before storing them.
Pinnacle Pad Cleaner seems to be an APC. Works the same on the pads and my lungs----so it's gotta be
I definitely would NOT use a hose and the rotary at the same time. One "well placed" squirt, leak, or broken hose and you'll be in trouble!!!!! |
08-19-2007, 02:58 AM
| | Member | | Join Date: Aug 2007
| | Quote: |
Originally Posted by D&D Auto Detailing I know this is a little late, but thanks for the review budman.
Scrub with brush
Rinse thoroughly
Squeeze out water
I find Woolite 8:1 & 10:1 to be more cost efficient, easier to rinse out, and cleans just as well. It should also be gentler on the pads. | Thanks!  |
03-29-2008, 04:17 PM
| | Junior Member | | Join Date: Mar 2008
| | | Re: New Technique- Pad cleaning GREAT Thread! But, WHAT is a "GRIT Guard"?
TKS Michael |
03-29-2008, 06:51 PM
| | Junior Member | | Join Date: Jun 2006
| | | Re: New Technique- Pad cleaning The Grit Guard is the black plastic thingy in the pictures in the first post. You put it in the bottom of your wash bucket to keep dirt particles from getting in your wash mitt/sponge. You can check it out in the webshop.
I have the system 2000 pad washer, and it works well for cleaning most pads. But it can't handle e.g. a really caked in wool pad, so sometimes I still wash pads by hand. It also worries me slightly that when using the pad washer, you don't actually rinse out the pad, you just spin it dry on the rotary, so there would still be a little bit of the wash solution left in the pad. I haven't noticed any problems with polishing pads, but especially for my wax pads I don't like the thought, so I will still rinse those. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
