Featured Photos
by admin
531 photos
23 comments
by admin
Sema Show 2008
433 photos
6 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Porter Cable 7424 & Pad Kit with CCS pads!
Tags: , , , ,
Reply
Thread Tools Display Modes
  #1
Old 06-05-2006, 09:04 AM
Orange & White Pad Debris Question
Used my new PC 7424 for the first time to smooth out some swirls on an '02 camry. First washed car and then clayed the surfaces to be polished. I was polishing in the garage, spritzed the pad with XMT pad conditioner and applied a ring of polish on the circumference of pad. I started out with the white pad with XMT #1. After a few applications in the same area, following instructions as I read online, I found that the pad would throw out small bits of debris when the polish began to haze. Not sure if the debris is the drying polish or the pad itself. Same thing happened when I tried the Orange pad with XMT #3 but a little worse. I also tried to brush off built up polish on the pads, and spraying on a bit more pad conditioner with pretty much the same result. I could get almost 3 passes zig zagging in opposite directions before the polished dried and the hazing began. Is this normal for small bits of material (pad or polish) to fling off? Am I doing something wrong? Your help is much appreciated.
Any recommendations on a more aggressive polish other than the XMT #1 & #3 to remove water spots and slight swirls?
Thanks
  #2
Old 06-05-2006, 09:20 AM
Neothin's Avatar
that would be dried up polish comming off. That's a signal that it's about time to add more polish to the pad.
xmt 3 should be able to handle almost anything you throw at it on a camry, especially wtih an orange pad. toyota paint is on the soft side of the spectrum and normalyl doesn't take much to correct. i would give it another go before you go try another product.
  #3
Old 06-05-2006, 09:28 AM
Hi Neothin,
Thanks for the quick reply!
I will try adding a "little" more polish from the start or slightly shrink my polishing area a bit to help avoid drying out the polish the next time.
Thanks again!
  #4
Old 06-05-2006, 11:15 AM
YES! Shrinking the area would help greatly.... 18 inch x 18 inch ........
  #5
Old 06-05-2006, 03:08 PM
Thanks
Did you see ANY imptovement? When you say that you used the 7424 for the first time, a lot of collateral questions arise regarding techinque. IMO defect removal results with the PC are very technique dependent. If you were not able to get even waterspots out with an orange cutting pad and XMT 3, I suspect there may be one or more technique issues. (That said, there can be some brutal waterspots, lets assume that that is not the case).Armspeed, pressure on the head, and probably a bunch of other things make a huge difference. You do not work the DA like you see people working the rotary. Mark your backing plate with a magic marker and you will see that while it may appear to be rotating at a mile a minute, if the pressure is right, it will be rotating maybe once or twice a second, so no reason to move quickly (to avoid burning the paint, as would be the case with a rotary). Another thing that happens to first time users is that they let the pad get saturated. As noted, keep to 18X18 for defect removal. You can swing bigger and faster (and at a slower speed) when you are applying wax. JMHO.
  #6
Old 06-05-2006, 08:29 PM
abrcrombe's Avatar
Good tips blackcoupe! A noob with a PC needs all the tips he can get. Thanks!
  #7
Old 06-05-2006, 10:20 PM
BlackCoupe,
Thanks for more great helpful hints toward my quest for paint perfection!
I worked the PC at a fairly slow pace as I worked the polish into a haze.
What is your definition of "saturated"? Sopping wet? Caked in the middle?
  #8
Old 06-06-2006, 12:04 AM
BlackCoupe,
My def: Saturated--soaking through to the top of the pad. Pad is heavy with product.
Do you have the PC on 5 or higher? The orange cutting pad with #3 should be making a big improvement. Then the white pad with XMT #1--sort of like a finer grit sandpaper. Then to the wax or some people use a really non-abrazive polish next and then to wax. If you are in the West Palm area, I wouldn't mind spending some time with you to show the little I know. EDIT: Oops! I see you are in Hawaii--maybe I'll come to you!
  #9
Old 06-06-2006, 02:23 AM
Now I know that I didn't have my pad saturated according to your def.
I started on 4, then moved on to 5 which seemed to lessen the vibration.
Thanks
Reply
« Newbie | PC noise ? »
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Lake Country Orange Pad question wolfpacker92 Auto Detailing University 12 06-10-2007 12:05 PM
2007 Pontiac G5 Nica Show N' Shine 36 05-27-2007 11:23 PM
Question about an Orange LC pad! ltoman Porter Cable 7424 & Buffing Pad Forum 13 04-28-2007 12:39 AM
Edge 2000 4" Pads - PRODUCT REVIEW MikeyC Auto Detailing Tools and Accessories 12 11-15-2006 06:59 PM
Review - No PC Palm Adapter, Edge 2000 Orange Wave Pad (Long) GearHead_1 New Car Care Products 1 06-05-2006 08:25 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
