06-29-2007, 04:12 AM
|  | Member | | Join Date: Jun 2007 Location: Maui HI
| | | I'm about to buy a PC, I think the EDGE will be fine for me. Polishing, applying wax weekend warrior. It be a long time before I put enough work into breaking anything! |
06-29-2007, 08:25 AM
|  | Administrator | | Join Date: Mar 2006
| | Please contact Meghan or myself and we will replace any of these items as they are under warranty. Odd things do happen with both systems at times, I just recently had a customer on another forum after using a backing plate for the 1st time the velcro some how melted. The good thing is that we have some great manufacturers that stand behind their products. So, if you ever encounter any problems please give us a shout and we will do our best to make it right.
__________________ Autogeek.net - We are car care Quote: |
"The true spirit of conversation consists in building on another man's observation, not overturning it." Edward G. Bulwer-Lytton
06-29-2007, 08:45 AM
|  | Senior Member | | Join Date: Feb 2007 Location: Rockledge, FL
| | Quote: |
Originally Posted by DavidJ021 What problems did you have with the schmitt?
Yeah i'm fine with my CCS & LC pads. They work fine. | The glue seperated after a couple of uses. They sent me a new one, and I have been using it (a lot) for 4 months without a single issue.
__________________
2005 Phantom Black Metallic GTO-M6
Head/Cammed-450rwhp/415rwtq
1/4--12.1 @ 118mph, 1.7 60'
06-29-2007, 11:43 AM
|  | Senior Member | | Join Date: Jan 2007 Location: Springfield, MO
| | | I will say the service from Edge was great. I had a blue pad fail after first use and it was replaced quickly, but it is frustrating to have stuff break. |
06-29-2007, 12:20 PM
|  | Senior Member | | Join Date: May 2006
| | | Look Guys,
One thing I have learned is that the PC is very hard on pads, backing plates, and adapters but we build our products to the highest standards, continue to improve them based on customer feedback, and stand behind the products 110%. There are problems with backing plates, and velcro all the time but people normally don't post done with LC, because everyone has velcro like LC, but only we have the quick connect system. Our pads are made from the same foam as LC and should last longer because they are double sides so all I can ask is that people give us the chance to make things right and we will.
Thanks, |
06-29-2007, 01:28 PM
| | Senior Member | | Join Date: Dec 2006
| | I must admitt that when I have read problems in the past with the Edge system it kept me from trying them out. I still wanted to try them out and placed my order last night. The problems seem to be few and far between. I would assume there are similar problems with velcro systems. I've not experienced problems with velcro and hope I continue this with the Edge system  |
06-29-2007, 01:40 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Chicago
| | Quote: |
Thanks, | Why not explain what your doing to improve your system instead of continuing to put your competitors products in all your replys..
I have always read/heard about your good CS and the fact that your always willing to rectify the problem..but to continue to bash the competitons product is unfair..IMHO un-professional
just an observation |
06-29-2007, 02:03 PM
|  | Senior Member | | Join Date: Jun 2007 Location: Metro Detroit Area
| | Quote: |
Originally Posted by joe.p Why not explain what your doing to improve your system instead of continuing to put your competitors products in all your replys..
just an observation | Umm, I didn't see anything that could even remotely considered "bashing"...
The edge simply stated specs... nothing more, nothing less?? |
06-29-2007, 02:04 PM
| | | I didn't see him bashing LC or other competitors in his post. I saw him making a comparison to a velcro backing plate and using LC as the example. Every system has issues. I very rarely see the velcro issues posted though. On my own car, the velcro failed and the pad flew into the yard. Requiring a drive of 1.5 hour drive to AG's warehouse to get a replacment (long weekend ahead and didn't want to wait).
__________________
06-29-2007, 02:09 PM
| | Senior Member | | Join Date: May 2007
| | Quote: |
Originally Posted by Jason Please contact Meghan or myself and we will replace any of these items as they are under warranty. Odd things do happen with both systems at times, I just recently had a customer on another forum after using a backing plate for the 1st time the velcro some how melted. The good thing is that we have some great manufacturers that stand behind their products. So, if you ever encounter any problems please give us a shout and we will do our best to make it right.  | Was that a Meguiar's backing plate by any chance?? I've had a Meg's bp ordered from Autogeek go bad through the heating of the PC and the velcro separating... it's very obvious as well because the velcro around the edge grabs onto the pad, then when you pull that off (slowly peel it from the edge, it just flies off since there's nothing holding it in the middle and very little resistance at edges. I just ordered LC backing plates from you guys since I've used one before for hours on a PC and felt no difference... if it's possible for you to replace my Meguiar's bp with an LC one that would be great... I'll PM you the details...
__________________
-Ivan
LUSTR Auto Detailing
|  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
