Quote:
Originally Posted by Surfer Maybe I confused you  , I already have the Edge 2K kit with the white/blue/orange/yellow/green pads. What I was curious about is the difference between the orange and green in the kit, I've heard some say the green is stronger, and others say the orange is stronger (as far as cutting ability). Both seem similar to me, which is why I was wondering what the difference between the two were? Especially since Edge's colors match up to difference cutting ability/ratings compared to other manufacturer colors. BTW you have two whites listed?
Didn't you just get the kit also? This system rocks  |
I've been using their system ever since the new adaptor came out, several months anyway. I love it. Here's the verbiage for the different pads as taken from AutoGeek's Edge page. The pads are ranked from most aggressive to least aggressive. I don't believe that the Pores/sq. inch are stated correctly in this ad copy and I've changed accordingly. I pulled the numbers I had posted from Edge's page (
http://www.edgepads.com/e2k6da_dbl.htm )and my conversation with Aaron on the orange pad. The orange pad isn't listed on this page.
The Edge 2000 6 Inch DuraFoam Pads are available in the following varieties:
Yellow Cutting Pad This pad is aggressive, and will cut through deep surface marks and swirls. They work well on heavy oxidation and pitted finishes, and will remove wet sand scratches without causing burning. 50 pores per inch (ppi)
Green Medium Cutting Pad This pad is useful for light oxidation and moderate to severe swirls and imperfections. This pad will yield amazing results on older vehicles, and should be used on vehicles with moderate swirls and imperfections. Add a compound or pre-wax cleaner for a flawless finish on base coats. 60 pores per inch (ppi)
Orange Light Cutting Pad This pad is highly versatile, as it can be used on cars with light to moderate swirls and imperfections. We recommend you begin with this pad if you are unsure how deep swirls are, moving up to a Green Medium Cut Pad if necessary. Safe on clear coats. 65 pores per inch (ppi)
Blue Finishing Pad This pad is great for everyday use. It will leave surface areas scratch-free and smooth while still removing light swirls and imperfections. Use with wax and polish to apply a fine gloss. Safe on clear coats. 70 pores per inch (ppi)
White Ultrafine Polishing Pad This ultra-smooth polishing pad contains 80 pores per inch, allowing for fine polishing which creates a bold, crystalline gloss Use this pad to apply waxes, polishes and sealants. Safe on clear coats. 80 pores per inch (ppi)
