Quote:
Originally Posted by detailgod so if i am reading this correct. the white and black are the same. only made white wool for those that are use to white wool being most aggressive. am i correct?
i know edge makes presta pads what i was wondering is. are the presta pads a cheaper line of edge pads or are they the same pads? |
Ok, so you are reading this right except for one small tidbit of info. When we die the natural white yarns black the die actually encapsulates the fiber and makes is microscopically a bit thicker and hence more agressive than regular natural white wool. This is idea for heavy cutting applications such as heavy oxidation, deep scratch removal, or wet sand removal. The other colored pads do not use dyed yarns but rather mixtures of synthetic acrylic fiber that is precolored. When mixing with natural white wool, the pad takes on the color of the acrylic ie: the Yellow pad is 50%wool 50% acrylic but the only color is from the yellow acrylic.
As far as Presta, they buy our Edge pads in our standard colors, not any cheaper version whatsoever, they are top quality only.
