06-16-2007, 06:00 PM
|  | Senior Member | | Join Date: Mar 2006 Location: spring hill, Fl
| | | its probably normal... and you dont need wave pads, just get the regular edge 2000 foam pads, wave pads are mainly for rotary polishers becaus of the heat transfer.
the PC is a unique machine. you really cant compare it to another orbital. |
06-16-2007, 06:32 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Norway
| | | If you say you "barly hold on at speed 5" something is wrong, i dont find my PC hard to hold at speed 5 or 6 myself.
Do you hold it against the car or out in the air?
__________________ EVOIX |
06-16-2007, 07:50 PM
|  | Senior Member | | Join Date: Jun 2007 Location: CA, bay area
| | | in the air |
06-16-2007, 07:53 PM
| | | Thats probably why it shakes badly, shouldnt be that bad when you use it on the car.
Still i cant say my PC shakes when hold in the air. I never tryed that
06-16-2007, 07:58 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Mass.
| | | It will vibrate like a banshee in the air...need to have on a surface...its a free wheeling concentric drive....try in on a surface next..polish your washing machine to get a feel of it...by holding in the air the energy transfer does not go to the pad...it vibrates the machine..
I notice when I am polishing and when I am ready to shut it off I lift it off the paint..the vibration gets intense then..much less on the paint..
AL |
06-16-2007, 08:53 PM
|  | Senior Member | | Join Date: Jun 2006 Location: Central Florida
| | | Does it spin freely without being on? Meaning, take the pad and simply turn it with your fingers. Does it spin with ease?? |
06-16-2007, 09:30 PM
| | Member | | Join Date: May 2007 Location: L.A. Canada
| | Quote: |
Originally Posted by dengood1 Does it spin freely without being on? Meaning, take the pad and simply turn it with your fingers. Does it spin with ease?? | Following along with your sig... should it spin, or should it not spin? |
06-16-2007, 09:42 PM
| | | It should definitely spin. |
06-18-2007, 02:19 PM
| | Senior Member | | Join Date: Apr 2007
| | | PUT The WASHER IN IT!!!!
__________________
CLICK IT.... I know you want to |
06-18-2007, 03:23 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Southern NH
| | | I guess I'll echo the above. The PC does vibrate. I use 7.5" pads with a 5" counterweight and don't have any issues so your 6.5" should be fine. If you were expecting to buy a machine with a 6" counterweight you should have bought the PC 7336. The 7424 comes with the 5" but luckily you can buy the 6" if you feel the need to. Make sure the pad is perfectly centered and make sure you actually use it this time and then report back to us.... |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
