Featured Photos
by admin
Before & After
13 photos
3 comments
by admin
Sema Show 2008
433 photos
13 comments
by admin
531 photos
29 comments
by admin
531 photos
29 comments
» Autogeek Car Care Products
Price match Promise
Reply
Thread Tools Display Modes
  #11
Old 06-15-2007, 11:23 PM
Rsurfer's Avatar
Quote:
Originally Posted by Thejoyofdriving
im sure AG will help me out. i doubt its something wrong with the pc, it could be, but then if there was something wrong what would it be?. i have already put the washer in, every thing is set up correctly as far as any one who has looked at it could tell. the main reasons why i want to switch to the wave 6" pads is because they are smaller and easier to center. Has any one had any sort of problems with these wave pads? are they less affective ?
I like the ccs pads better or even the flat pads. I beleive that the wave pads are great for a rotary.
  #12
Old 06-16-2007, 12:33 AM
Jimmie's Avatar
You jumped from I can barely hold it to what pads should I use. You've got me confused and I'd like to help.
  #13
Old 06-16-2007, 01:10 AM
Thejoyofdriving's Avatar
D&D auto detailing yes, I do have a detailing buissnes why? what does this have to with my problem if you dont mind me asking
  #14
Old 06-16-2007, 01:40 AM
ltoman's Avatar
come on guys, jimmie always tries to help everyone - just the usual misunderstanding because email has no emotion like voice. no intonaton makes it easy to misinterpret.
__________________
Vette Princess ltoman
2007 Z51 Red Corvette ~ my baby
2006 Berry Red Saturn Relay ~hubby's baby
2001 Gold Saturn SW2 ~family beater
1998 Dk Green Metallic Plymouth Voyager Expresso ~ ebay mobile
  #15
Old 06-16-2007, 03:17 AM
jimmie, what i was saying is that my pc is having some balancing issues and that i belive that it could be caused by the counter weight being too small for the 6.5 inch pad, because the counter weight that came with my pc is for a 5 inch pad. so i was thinking of buying some edge 2000 wave or edge 2000 DA pads because they have nice system to insure proper pad centering and because they are .5 inch smaller. plus i also plan on buying a 6" counter weight
  #16
Old 06-16-2007, 07:42 AM
Al-53's Avatar
Vibration is the nature of the beast with a PC....How much vibration you have is hard to tell...I use a 5" in weight on 6.5 inch pads and it vibrates..but not like you say yours does..I even changed weights and not any real difference....
I mainly use 5 or 5.5 in pads now..made a world of difference...
now going to the edge may help..but you would be better off with the flat pads..the wave pads are mostly designed for rotary ..the flats pads will give you more surface contact with less downward pressure wers as the waves you will have to compress them more to get more pad contact on the paint..that will cause the PC to sorta bog and heat up...
another thing is to try the PC with out the handle...and use one hand on the black plastic cover in front of the machine..the removal of the handle does seem to reduce the vibrations...
do not exert a lot of downward pressure and do not over load the pads with polish...saturated pads will cause a out of balance also...not that you did..just a tip...
Hope you get this squared away..
Al
  #17
Old 06-16-2007, 08:55 AM
killrwheels@autogeek's Avatar
Moderator
the weight will likely be a product never used, upgrading to Edge system is one we all agree is a nice choice. Vibrations however, are likely here to stay.
  #18
Old 06-16-2007, 09:29 AM
Meghan's Avatar
Moderator
Quote:
Yes the counter weight will not make a difference, no one yet has found any difference between the two. As for vibration... its a DA PC yes it vibrates. Nothing we can do to change that. But if you need help give me a call I am in the office today.
Thanks
__________________
Ralph Waldo Emerson -
- Do not go where the path may lead, go instead where there is no path and leave a trail.
1-800-869-3011 ext 207
meghan@palmbeachmotoring.net
Stop By the Store and Look Around!
Check out new products!
Porter Cables with Free Bonus
  #19
Old 06-16-2007, 12:23 PM
I have compared my pc to a friends orbiter, and his does not vibirate nearly as much as mine does.
  #20
Old 06-16-2007, 05:46 PM
Rsurfer's Avatar
You need to compare it to another pc. Apples to apples.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
