Quote:
Originally Posted by roadrunner1659 bogging as if the spinning action would stop...it never did that... |
the orbiting will not stop....the motor sound my drop a pitch or 2...I seen your other post where you said the gray motor enclosure was hot to touch..thats the armature cover...so it was over heating..you may have a bad one or you may have over worked it....try doing it with just the machine weight and some pressure and see if it heats up...if not then you used alot of pressure...if it heats with little to none than you have a bad machine....
Al
