Featured Photos
by admin
531 photos
29 comments
by admin
531 photos
29 comments
by admin
531 photos
29 comments
by admin
531 photos
29 comments
» Autogeek Car Care Products
Price match Promise
Tags:
Reply
Thread Tools Display Modes
  #31
Old 05-14-2007, 06:28 PM
Rsurfer's Avatar
Quote:
Originally Posted by Al-53
I am not trying to bad mouth a product here...But I have 4"...5"CCS...5.5 LC...and 6" CCS pads and I can put pressure on them to the point of almost flattening them and get rotation..If I had a video cam I would show you...I have put some serious downward pressure on them and they still spin... I am not favoring one pad over another..just stating a fact...even my old Edge classics will spin...it could be a optical illusion...but they look like spinning to me as I have a red 1" dot on my backing plate and its a solid red blur 360 degrees on speed 5 and 6....
AL
Hi Al, I have followed your posting for some time now and highly respect your views and comments. I beleive what you are saying is true. I too have put a black X on my backing plate and the edge pads do not rotate with 5lbs. of pressure, however my LC ccs pads do rotate even with 15-20lbs. of pressure. I changed the counter weight from 5" to 6" and it did help a bit, but still stops rotating with a little pressure. I also used the edge with and without washers. The theory behind the edge pads are terrific: Self centering, 2 pads in one, easy connect and disconnect. Any suggestions Al would be greatly appreciated.
Sorry I meant an x on the side of the edge pad.
  #32
Old 05-14-2007, 07:49 PM
MikeyC's Avatar
I've used both LC and Edge pads and IME they both spin the same. I will add that it is awfully hard to see if the Edge pads are spinning. There is no mark or reference point for your eye to follow where as a backing plate usually has some kind of mark on it.
Anyway, I'm not sure why people are always SO obsessed with whether the pad is spinning or not. As long as the pad is orbiting then it's still polishing. I only look to see if the pad is spinning to guage how much downward pressure I'm applying.
I'd also like to add that I've had my Edge pads for I believe over a year now and despite many polishing sessions they still look and perform like new. Plus, I'm still using the same adapter which also looks and performs as new.
__________________
Check out the FREE detailing guide I wrote!!
http://www.TheDetailingHandBook.com
You like Nattys, I like Souveran, and Justin is DP MaxWax. And you know what, its alright !!
-Killrwheels
  #33
Old 05-15-2007, 06:39 PM
I love my Edge Pads. I did notice a small tear about 3/8 inch developing on my blue pad about a half inch from spindale opening(around 6 uses). Think I should toss? only problem I have had.
__________________
Brian
  #34
Old 05-16-2007, 03:11 PM
Adde's Avatar
seems to me a lot of the blue pads tear in that exact spot around the opening Im going to email aron with a pic of mine and send it back seeing if I can get a new one this is only 2nd use
__________________
2000 Dodge Durango 5.9L 4wd
  #35
Old 05-16-2007, 04:03 PM
Quote:
I don't understand either. The PC is not designed to "spin" the pad at all. The spinning is just a byproduct of the physics of the machines orbitting. You put some pressure on the machine and any pad will most likely stop "spinning" at some point. Some may do it quicker than others.
__________________
  #36
Old 05-16-2007, 05:31 PM
Quote:
Bothersome to say the least. I wonderd f I was the only one that experienced it.
__________________
Brian
  #37
Old 05-16-2007, 05:52 PM
budman3's Avatar
Quote:
What is the name of the PC? Porter Cable 7424 Dual Action Polisher. If the pads are not meant to spin, can you please name the two actions that this polisher does?
  #38
Old 05-16-2007, 07:17 PM
Nimble's Avatar
Quote:
Budman does have a pretty solid point there.
__________________
Justin's Auto Detailing
Owner/Operator
  #39
Old 05-16-2007, 07:29 PM
This has been gone over before in another thread, but the machine does not have a forced rotation. It only orbits around the axis in the jiggling manner. As you know, you can freely spin the pad when the machine is off. So when the machine is on and orbitting, it is free to "spin" like you are talking about. But then once you put enough pressure on the pad, it will stop spinning. In case I was mistaken by having a defective machine, I did confirm this with Porter Cable.
__________________
  #40
Old 05-16-2007, 07:43 PM
Al-53's Avatar
well then I have a different machine then..with a 5.5 in pad I can put severe pressure on it to the point I may push the panel in and it rotates...to the point where my red dot is a swirling red blur 360 degrees...its not a forced rotaion...it is centrifical rotation...if the pad is not grabbing the paint and jiggling then it will rotate and orbit at the same time..thats why they put lubes in polish to reduce friction...so something is grabbing the paint....it works on cocentric motion..
look at a pad the jiggles..you see your polish dots on the foam...look at a pad that rotates...you see polish on the whole surface...so with rotation and orbits you get a different pad area each orbit and polish covering all areas ..with a jiggle you get the same area working the paint more or less
AL
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Edge 2000 Pad cajunwoodrick Porter Cable 7424 & Buffing Pad Forum 4 05-02-2007 01:50 PM
Edge 2000 4" Pads - PRODUCT REVIEW MikeyC Auto Detailing Tools and Accessories 12 11-15-2006 06:59 PM
Edge 2000 Wave Foam Pads- NEW ONES!!! Meghan New Car Care Products 10 07-13-2006 08:08 AM
Review - No PC Palm Adapter, Edge 2000 Orange Wave Pad (Long) GearHead_1 New Car Care Products 1 06-05-2006 08:25 PM
Edge 2000 Porter Cable Complete Kit Meghan New Car Care Products 11 05-20-2006 06:36 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
