Featured Photos
by admin
Sema Show 2008
433 photos
13 comments
by admin
531 photos
29 comments
by modular
Exterior Gallery
65 photos
33 comments
by admin
531 photos
29 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Tags: ,
Reply
Thread Tools Display Modes
  #51
Old 07-07-2007, 06:34 PM
Sa//|XP's Avatar
Member
No, the PC uses sealed bearings. No need for lubricant. The PC barely gets warm, as long as there is no binding. The spacer solved the problem in the original post.
__________________
  #52
Old 07-07-2007, 06:59 PM
Quote:
Originally Posted by DanielSwe
I'm not a PC user (yet) but would it help to open the "house" and put it some new lubricant?
I would definitely check on that with A.G.
  #53
Old 07-07-2007, 09:07 PM
D&D Auto Detailing's Avatar
Havent read the entire post. But if your PC is over heating then make sure your pads are secured and centered.
__________________
D&D Auto Detailing
-Dan
  #54
Old 07-07-2007, 11:12 PM
I just started using the PC. I found that it was getting too hot to hold and bogging down. When I found this thread I tried adding the spacer. It made a HUGE difference. Now I see why people use this machine. Thanks for the advice!!
  #55
Old 07-08-2007, 12:38 AM
r_wain's Avatar
Never had a problem with it till today. I use the edge system and went to change pads and burnt the crap out of my finger on that little release button. It was also 96 degrees outside maybe that had a little to do with it.
__________________
Rob
  #56
Old 07-08-2007, 04:46 AM
DanielSwe's Avatar
Quote:
It's good to have a swift solution right there bro. But tell me, does the lubricant inside these machines last for years if you use them every day? I might be overzealous but to me it's like changing oil on the car to clean out the house and put in new lubricant. Just my 0.02.
  #57
Old 07-15-2007, 09:47 PM
it is using "sealed" bearing.... you cant relube them... they are lubed at the factory and they then place a cover over the bearings housing... no way to put lub in ......
  #58
Old 08-19-2007, 08:54 PM
hot and bogging down
sure glad i read this forum before complaining, got my pc 7424, couldn't wait! then started on my nova. so dissapointed. put the machine on the car and it stopped. got very warm. put it all back in the packing, paid this much and can't use it!then came in and started checking the forum. felt like a fool, but was happy i checked it out.found out about little gray spacer,( which in my opinion should be attached at the factory because of idiots like me who don't read directions), went out, found it in the trash, put it on, works like a charm. thanks guys!!!
  #59
Old 08-19-2007, 09:04 PM
joe.p's Avatar
Quote:
Originally Posted by BILL
NOT SURE......BUT IT IS NOISY AND DOES GET WARM......
Yes it is noisey,vibrates quite abit..AL-53 said it is best to use a construction grade ext cord to eleminate the PC from over heating..eliminating over heating my also help some of those with BP issues..
__________________
  #60
Old 08-20-2007, 10:01 AM
Member
mine gets normally warm for what it does...i wouldnt expect it to be any cooler
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
7424 or UDM Cashcrazy Porter Cable 7424 & Buffing Pad Forum 4 12-30-2007 02:03 AM
Recieved another HOT CHECK. Advice on this one. TexasTB Off-Topic 34 10-28-2007 08:24 PM
Hot Water Extractor!!!! trhland Auto Detailing Forum 28 02-14-2007 09:31 AM
PC 7424 and PB SSR 1 & 2.5 for sale dakevmann Car Care Product Giveaways 4 09-28-2006 05:49 PM
NEW Porter Cable 7424 HD Plus Meghan New Car Care Products 22 06-23-2006 06:29 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
