05-01-2007, 10:17 AM
|  | Senior Member | | Join Date: Jul 2006 Location: Ft Lauderdale, Florida
| | | So if I am using an LC Orange pad with XMT360 and it didnt remove all of the light swirls what should I do?
__________________
Darren
05-01-2007, 10:24 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Southern NH
| | | Bump up to a stronger polish and switch to a polishing pad. You could try XMT2 or SSR1 and see what happens. XMT360 isn't necessarily a swirl remover, rather an all in one product... so you may need to bump up the polish. Remember that the orange pad with any product will leave micromarring |
05-01-2007, 10:30 AM
|  | Senior Member | | Join Date: Feb 2007 Location: Chicago, IL
| | | if org and 360 isn't working, then no way will a white pad with ssr1 work, which imo does about nothing to remove marring. Don't be afraid to get some work done. Grab the ssr 2.5 and a white and see if that works, if not bump back up to the org pad and then do 360 with the white pad to finish off. |
05-01-2007, 10:36 AM
| | | after using the XMT360, the car looked and felt nice except for the few swirls..The only issue was that the XMT seems to melt right in to the paint so I was thinking maybe I just didnt work it in long enough and was getting a little nervous that I didnt have enough product on the pad
__________________
Darren
05-01-2007, 11:03 AM
| | | not your fault, a one step cleaner wax (which is all that 360 is) will never have enough "grit" to remove more than a few spiderwebs. The pics on here of it show it to be a miracle worker, but 1/2 that is just fillers and sealant hiding the rest of the flaws. It's good stuff, but is only "one step" if you have a near perfect car. Add a step before it to remove the deeper marring and then use the 360, I think you'll be pleased with the results. |
05-01-2007, 11:13 AM
| | | actually bought the 360 because I don't generally have a lot of time to take care of my car as I would like...Between working in the car business and a 15 month old baby I'm lucky I have the time I do...can anyone recommend anything?
__________________
Darren
05-01-2007, 11:21 AM
| | Senior Member | | Join Date: Jan 2007 Location: Grand Rapids MI
| | I havent found much use for cutting pads with my rotary. I find that polishing pads and finishing pads can do quite a bit.
edge2K 6" blue
OC 600-1500-600 rpm
OP 600-1000-600 rpm
With a PC i find i do need to use a cutting pad becuase the machine is so gentle to begin with. |
05-01-2007, 11:31 AM
| | Quote: |
Originally Posted by Darren F can anyone recommend anything? | is this a serious question? we've *been* recommending something. One steps WILL NOT a perfect finish get. Period. Divide the work up on 2 steps. This isn't rocket science, the proven tactics still work the same as they always have. |
05-01-2007, 12:00 PM
| | | It is a serious question...My issue is I dont really have the time do do it all at one time unless I polish in the evening and finish up the next day using a spray sealant or wax...Or I will just have to continue to deal with the the AIO's and do the best I can
__________________
Darren
05-01-2007, 07:28 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Alberta, Canada
| | Man this is a wicked topic...I've learned lots wow...keep it coming  |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
