Featured Photos
by admin
Exterior Gallery
65 photos
33 comments
by modular
Exterior Gallery
65 photos
33 comments
by admin
531 photos
29 comments
by admin
Pinnacle Products
11 photos
20 comments
» Autogeek Car Care Products
Dodo Juice Car Waxes
Reply
Thread Tools Display Modes
  #11
Old 04-24-2007, 09:54 PM
Some cars need stronger cut pads, an Edge blue with OC wouldn't do squat to one of our cars with hard clear. OC and yellow Edge cutting pad got maybe half the swirls out. My trucks is fairly easy to correct, yellow or green Edge pad and OC and I can get it to finish down like a polish with no marring, it's all in the technique.
__________________
The real WyStang:
  #12
Old 04-25-2007, 02:57 PM
budman3's Avatar
Quote:
Originally Posted by scottgt
im gonna do a test wen i get my new pads
Me too... now all I have to do is find the right canidate for a car...
  #13
Old 04-25-2007, 03:00 PM
scottgt's Avatar
haha...i got my other door to do an it will be great...
  #14
Old 04-25-2007, 03:04 PM
P1et's Avatar
24 HR Queue
The short answer is that people want to get instant gratification. Aggressive pads with an aggressive polish will get the scratches out. Level it off with an SSR1 on a white pad or something to that effect and you're done.
  #15
Old 04-25-2007, 03:45 PM
richy's Avatar
I use the pad/polish combo based on the paint condition. I tend not to change pads with a single product, I will change to a lesser cut or polish along with the pad change.
  #16
Old 04-25-2007, 08:03 PM
INMY01TA's Avatar
Member
I try not to use my LC orange pad for this reason.
__________________
My FQuick page
  #17
Old 04-27-2007, 11:45 AM
Nimble's Avatar
Meh, I've done lots of cars where a LC white and OC or SSR 2.5, etc didn't do enough. The aggressive pads are made for, well, aggressive defect removal, and surprise, that's what I use them for. This isn't rocket science fellas.
  #18
Old 04-28-2007, 12:53 AM
David Fermani's Avatar
I'd rather reach for a medium polish with a wool pad instead of a heavy polish on a cutting foam pad any day of the week. I personally think that wool is for removing the defect and foam is to create depth. Defects *can* be worked out with foam, but I prefer the easier and faster route with wool.
  #19
Old 04-28-2007, 07:09 AM
orngez's Avatar
Quote:
i prefer to go the foam route...yes wool does an amazing job of removing defects...but it also removes a ton of clear in the process...just for example (the numbers are just hypothetically speaking)....if you had a scratch that was 5 microns deep...foam can finesse the paint enough so that it removes 5-7 microns...wool wood remove 8-10 microns in the same process..in both scenarios the defect is removed but one was overkill...not the case in every situation but i prefer the minimalist route ...basically the minimun clear coat a foam pad can remove is less than the wool pad...and if the foam pad is enough to remove the defect why risk removing more?
__________________
  #20
Old 04-28-2007, 12:52 PM
Quote:
I don't think this is accurate. Wool will cut cleaner, faster and cooler where foam is the opposite. It heats the paint up more, melting more of the surface around it while you remove the scratch. The best way to remove a scratch and trying to preserve paint at the same time is to just wet sand the scratched area. That way, removing too much paint isn't a concern. Each pad has it's place, but for cutting, wool (I think) is the most effective pad unless there's a special issue with paint harness/softness. I try to avoid using wool on black Mercedes unless I'm removing wet sand scratches(3000 grit and coarser). If I was removing 4000 grit sand scratches on that car, I'd use a cutting foam (yellow EDGE). For a black Corvette, I'd have no problem using a wool for heavy defect removal. Everyone has their own procedures I guess.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
best pads. high vs low profile, flat vs ccs Mr Dream Machines Porter Cable 7424 & Buffing Pad Forum 0 08-17-2007 04:00 AM
So what is the verdict? CCS pads or good ole' flat pads? Avengeance Porter Cable 7424 & Buffing Pad Forum 10 08-01-2007 05:43 PM
4inch pads Nica Porter Cable 7424 & Buffing Pad Forum 8 03-04-2007 02:21 PM
Edge 2000 4" Pads - PRODUCT REVIEW MikeyC Auto Detailing Tools and Accessories 12 11-15-2006 06:59 PM
Mega Cyclo Polisher Kit admin New Car Care Products 13 04-21-2006 03:40 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
