7.5 or 8.5 edge pads for rotary
Porter Cable 7424 & Buffing Pad ForumDiscuss 7.5 or 8.5 edge pads for rotary in the Buffers and Polishers forums; Torn between the 7.5 or the 8.5 for swirl work and polishing of these two sizes for my ...
Torn between the 7.5 or the 8.5 for swirl work and polishing of these two sizes for my rotary, what do you guys use and why??? already using the 6.5's but want to change......
Bill ..years ago I used 7.5 and 8 inch pads for the buffer...I found I was getting buffer hop...holograms from not holding pads flat and using the edge ...could not get into tight areas..so I took a 7 inch backing plate and cut it down to 5.5 inch and used 6 inch pads..was night and day with results...more control..no holograms...could get in more areas...and seemed to use less product..and less product sling as the bigger pads used alot of product the keep wet for less hop..
The 8.5's will get more RPM and cover more surface area but there is more risk of damage. It's up to you. Since I'm still learning the rotary, I'm using the 6's for now. I just have to turn up my machine more to get the equilivelent RPMs.
thanks guys........ill stick with my 5"plate and 6.5 pads
i know im also looking at the 6.5 curved edge pads....a little change in pad for me... But now im NOT finding them, i guess they don't make that size in the curved
