» Autogeek Car Care Products | | |  |
02-19-2007, 06:57 PM
|  | Senior Member | | Join Date: Jan 2007 Location: Honolulu, Hawaii
| | | Edge 2000 pads Just used the foam pad conditioning brush on my edge pads. The green and blue pads came out great, however, when I brushed the white pad, it started to shred the foam. I did not use the pc, but did it by hand. Pads were dry before I started to brush. Maybe you shouldn't brush the white pad cause it's to soft??? Wish ag or edge would have said something. The brush is advertised on edge web page. Any comments from the forum. |
02-19-2007, 11:55 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Alberta, Canada
| | | Interesting how you had problem with your pads too, I to seem to be experiencing some problems with mine but I'm not sure if it's normal or it it's just me miss treating them. So I too posted. Hope others chime in to help just wanted to post and to be kept informed...that's all. |
02-19-2007, 11:59 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Massachusetts
| | Quote: |
Originally Posted by Rsurfer Just used the foam pad conditioning brush on my edge pads. The green and blue pads came out great, however, when I brushed the white pad, it started to shred the foam. I did not use the pc, but did it by hand. Pads were dry before I started to brush. Maybe you shouldn't brush the white pad cause it's to soft??? Wish ag or edge would have said something. The brush is advertised on edge web page. Any comments from the forum. | I had that happen once with a white Lake Country pad which is nowhere near as soft as a white Edge pad. Ever since then I've not used the brush. If the pad gets crusty I just flip it over. After I'm done I clean the pads with some XMT Pad Cleaner so no brush necessary.
__________________
Check out the FREE detailing guide I wrote!! http://www.TheDetailingHandBook.com
You like Nattys, I like Souveran, and Justin is DP MaxWax. And you know what, its alright !!
-Killrwheels
02-20-2007, 12:34 AM
|  | Senior Member | | Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| | | I just posted on Nica's thread. My white Edge pad started pitting and shredding. No brush was used. Same thing happened to the blue pad but not as bad. The firmer pads are OK. |
02-20-2007, 08:04 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Brownsburg, Indiana
| | | With Edge's reputation for great customer service, it might not be a bad idea to contact them directly.
__________________
-Mike Driven Auto Detail '07 Tacoma TRD Sport 4x4 Double-Cab | Indigo Ink Pearl '05 Mazda3 SP23 Hatchback | Carbon Gray Mica |
02-20-2007, 05:57 PM
| | | edge pads I did contact aaron at edge and he said that all pads should be brushed using the pc. He even sent me a link showing this. However, ag link shows a photo of cleaning a white pad in a bucket using the brush. One say's don't and the other says it's ok. I guess to be safe you should clean by hand and don't use the brush. I have no problems with the other pads. There are tiny tears in the foam. This might trap debris, so i'm throwing it in the trash. Ashame since I only used it twice. I will use the good side first. lol |
02-20-2007, 08:27 PM
| | Senior Member | | Join Date: Apr 2006
| | Quote: |
Originally Posted by Rsurfer I did contact aaron at edge and he said that all pads should be brushed using the pc. He even sent me a link showing this. However, ag link shows a photo of cleaning a white pad in a bucket using the brush. One say's don't and the other says it's ok. I guess to be safe you should clean by hand and don't use the brush. I have no problems with the other pads. There are tiny tears in the foam. This might trap debris, so i'm throwing it in the trash. Ashame since I only used it twice. I will use the good side first. lol |
i just soak and hand agitate.......no brushs  |
02-20-2007, 11:14 PM
| | Quote: |
Originally Posted by Rsurfer I did contact aaron at edge and he said that all pads should be brushed using the pc. He even sent me a link showing this. However, ag link shows a photo of cleaning a white pad in a bucket using the brush. One say's don't and the other says it's ok. I guess to be safe you should clean by hand and don't use the brush. I have no problems with the other pads. There are tiny tears in the foam. This might trap debris, so i'm throwing it in the trash. Ashame since I only used it twice. I will use the good side first. lol | What throwing them away...oh...your gong to use the other side  I was going to say send them my way I'll use those baby's up hahahaha.
I always spray the XMT pad cleaner and then use a tooth brush to brush some stuff off. Has not given me any problems yet. |  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
