Hi everyone. new to this forum. Just discovered AG a couple weeks ago after scoring a great deal on a PC 7336SP for $50. Needed pads etc and found my way to AG. Very glad I did. Seems to be a great community!
The PC 7336SP has identical specs to the 7424 except it's packaged as a DA sander/polisher. And it works beautifully!!
Anyone else have any experience with the model 7336SP I found? And incidentally it was at Lowes in a close-out bin.
I got a set of LC CCF pads and used them last weeked. With 3M Perfect it foam polish I got beautiful results in just a couple hours. 90% of the swirl marks are gone but some old water marks held on. I think I need to go a bit more aggresive. Going to order Perfect-it II machine polish. I used the light cut green pad. Probably should go to the orange and work the polish longer too. Does that sound appropriate?
I didn't use a sealer as I had a fresh tin of Meguirs NXT paste, which I like.
She looks really nice, but I think I can get a much deeper richer shine and am thinking of taking advantage of the Sourevan sale.
This is on my 2000 Bright Red BMW 328ci sports coupe.
My Problem ---
Everything went great till I applied the NXT Paste. It went on fine and looks great, but the gray LC CCS pad seemed to absorb Huge amounts of the paste! I used over a third of the tin on one coat. And the pad weighed about three times the new weight afterwards (it's been drying for 3 days and is still moist) . Like I always did with with the double-handed orbital buffer I used to use I applied the NXT paste to the pad by "buttering" it with a butter knife. May sound weird, but it's always worked fine before.
Now, before I drop the cash for Sourean, I need to find out how it should be done! I figure I should get 6 to 8 coats out of a tin. Am I off base?
All advice welcome.
Thanks All,
