Backing plate question
Porter Cable 7424 & Buffing Pad ForumDiscuss Backing plate question in the Buffers and Polishers forums; Is the backing plate supposed to be screwed on or does it just go into the pc? The backing plate ...
Is the backing plate supposed to be screwed on or does it just go into the pc? The backing plate I order wasn't able to get screwed on so if I flip it upside as if I were to work on a car it would fall off. I know this is probably a super newb question but I figured it'll screw on just like pad that came with the pc.
__________________
2005 Tarmac Black Evolution VIII
Well that means the one I have is broken. It won't screw onto my pc like the white pad that came with the PC. The part that screws on isn't big enough. I guess i'll call customer service.
__________________
you may have gotten a rotary plate which has a female thread on the plate where the screws into the thread....where as a PC has a male thread which screws into the PC.....
if your plate has a hole on top with threads inside it..then it is a rotary plate....
if it has a screw type thread on top like the PC original white pad has it should work then...
look on AG at the plates..look at a rotary one and a PC one..see which one you have
By the way some of my stuff was kinda frozen when it got here. I bought xmt 3, xmt 1 and the xmt pad conditioner and cleaner. They were kinda frozen so I hope they are still good.
__________________
well if that is the plate you ordered...and it does not have a male thread on top..then you indeed got a bad plate.....
as for your frozen products..warm them and shake them...shake often till they feel room temp...do not try to heat them...let them warm normaly...but shake every 10 minutes..till they feel room temp...after they thaw and they look creamy..they should be ok ..if like cottage cheese...call AG..
