The following are instructions to maximize the usefulness and service life of your Edge foam buffing pads. If you'd like to print these we recommend that you
download a copy (requires Adobe Acrobat Reader). If you don't have Acrobat Reader, click on the icon at right for a free download of the Acrobat Reader software. You don't need Acrobat to view the online Care Instructions below.
QuickFind
Click below to jump
to a topic A. Connecting adapter and pad B. Removing pad C. Removing the Adapter D. Buffing instructions Proper care extends pad life Watch the Video A.To connect drive adapter and pad 1. Attach drive adapter to buffer
Screw the chromed drive adapter tightly onto the buffer's threaded shaft.
If you need to remove the adapter,
see C below.
2. Align hexes
Holding the pad and buffer firmly in each hand, center the pad over the adapter and rotate it until its hex aligns with the hex top of the adapter.
3. Snap pad in place
Snap the pad firmly onto the adapter. If you don't hear a snap, test the connection by wiggling the pad. Make sure the pad is firmly snapped onto the adapter before turning on the buffer.
B. To remove pad 1. Position drive
With pad and adapter mounted on buffer, hold adapter with your left hand, with thumb and knuckles pressed against pad.
2. Press button
While holding buffer in left hand, grasp pad with right hand and press one finger against the release button in the center of the drive adapter.
3. Push off pad from the back
Press the release button while pushing the pad away from the buffer. The pad will release with moderate pressure.
C. To remove the Adapter
While pad is still mounted on drive, hold down lock button on machine and twist the pad with the other hand. This will unscrew the adapter
from the buffer shaft.
Never use tools on the adapter.
• To disconnect adapter, place buffer on a secure surface and rotate the pad while it’s attached to the adapter.
• Adapter tension is factory set and must not be changed. Any attempt to adjust the tension may cause the pad to disengage while in use
D. Buff flat to prevent damage WARNING! Never buff at a sharp angle.
Always buff with the pad as flat as possible against the car's surface.
Buffing at an angle greater than 10 degrees will cause unsightly swirl marks and severely damage the car or pad. If you notice excessive pad wear, replace the pad immediately.
Edge™ Pads manufacturer and distributor will not assume liability for any damage caused through misuse or improper procedures. Operate at 1800-2000 RPM
—NEVER exceed 2500 RPM
