removal with microfiber bonnetts
Porter Cable 7424 & Buffing Pad ForumDiscuss removal with microfiber bonnetts in the Buffers and Polishers forums; what speed should i be set on to remove the poor boys swirl removal #1 and the poor boys EX ...
what speed should i be set on to remove the poor boys swirl removal #1 and the poor boys EX sealant? i got the wool levelng pad and the micro- fiber bonnetts but i need to know what speed to use on the pc to remove as opposed to apply? also in your opinion , do you think the poor boys EX will work to protect this winter?
wool is extremely abrasive, it is a true cutting product. I highly suggest using several abrasive pads first. SSR 1.0 is a finishing polish so not very abrasive in itself.
You can use the wool pad covered with the bonnets for wax or sealant removal. No need for speed ... around 3 max. Just as easy via hand.
