10-16-2006, 07:43 PM
|  | Junior Member | | Join Date: Oct 2006
| | Quote: |
Originally Posted by supercharged If you are looking for best durability sealant - Klasse twins is the way to go. Two coats of SG 12-24 hours apart in absolutely dry conditions should last you 4 months. Then top it off with liquid Souveran and you are all set for winter.
That's my plan of attack for my RL. | Would Klasse replace the XMT and glaze steps, or is that in addition to? |
10-16-2006, 07:45 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | swirl removing = polishing
same thing. Start with the least abrasive polish (finishing) and move your way to most abrasive (compound) only as needed. Pad choice can also help as light pads (finishing) and heavy or firm pads (aggressive). Then once the swirls are gone (car is then polished) you can move back down to the lightest polish and pad combo to jewel or gem the surface.
Sealants --- DP Shield Shine (green version), Poorboys EXP, Klasse SG, Wolfgang Concours |
10-16-2006, 08:03 PM
| | Quote: |
Sealants --- DP Shield Shine (green version), Poorboys EXP, Klasse SG, Wolfgang Concours | OK. I think I got a bead on it now... Thank the gods I can work on networks, cause if I had to make a livin' detailing cars I would starve..
Wash with DP
Clay with the WG kit from ag.net
polish with the XMT and orange pad
seal with WG Deep Gloss paint sealant.
Wax with http://autogeek.net/pinsouvwax.html, if there is something better on ag.net, please let me know.
Question. For the sealing and wax would I use the blue, or white pad, or does it matter?
Thanks for you help!
10-16-2006, 08:08 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Hendersonville NC
| | | Yep I think you got it now! |
10-16-2006, 08:14 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Mountville, PA
| | This is what EDGE pads suggest Quote: | White Ultrafine Polishing Pad This ultra-smooth polishing pad contains 80 pores per inch, allowing for fine polishing which creates a bold, crystalline gloss Use this pad to apply waxes, polishes and sealants. Safe on clear coats. 80 pores per inch (ppi)
| But, why don't you apply by hand? It's really easy, and you can get into places your PC can't. Less waste of product too.
__________________
Alban B-)
2008 Ford F250 XLT 6.4L PSD, 4X4, SC, SB, Bedrug bedliner, Torza Trifold Tonneau cover, SS step bars / Dark Shadow Gray Metallic
2006 Nissan Sentra 1.8S / Inferno |
10-16-2006, 08:18 PM
| | Quote: |
Originally Posted by alban61 This is what EDGE pads suggest
But, why don't you apply by hand? It's really easy, and you can get into places your PC can't. Less waste of product too. | So there's no real need for pressure when applying sealants and waxes? If so, your're probably right. By hand would be the way to go.. |
10-16-2006, 08:23 PM
| | You're right, there's no need for pressure at all. After all the "abuse" from the PC/XMT, it's time to "love" the paint with your sealant and wax.
__________________
Alban B-)
10-16-2006, 08:53 PM
|  | Senior Member | | Join Date: Mar 2006
| | Quote: |
Originally Posted by mrodriques Would Klasse replace the XMT and glaze steps, or is that in addition to? | XMT (3,2,1) will remove swirls, as for glaze - don't use it if you are going to use a sealant, otherwise sealant will not bond properly to paint. Matter of fact I highly recommend rewashing or alcohol/water mix wipe down after XMT. When sealant will cure, apply a couple coats of Souveran.
You will be pleased with results.
__________________
1997 Acura 3.2 TL (sold)
10-17-2006, 08:53 AM
| | Souveran paste! It's absolutely amazing on black.
__________________ Oye como va mi ritmo bueno pa gozar |
10-17-2006, 11:07 AM
| | Senior Member | | Join Date: Sep 2006 Location: In the Garage
| | I would put a layer or two of Collinite 845 / 476 on top of your sealant, then top that with Souveran if you want.  |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
