10-16-2006, 04:04 PM
|  | Moderator | | Join Date: Mar 2006
| | | The PC dial just has whole numbers, 1,2, 3, 4, 5 and 6. there is no 5.5 marking. I just find mine by sound. I crank it up to six and then just tap it back some very slightly to where the sound changes. Regardless, if you run the PC at 5 or 5.5 it will still accomplish a beautiful finish.
__________________ Oye como va mi ritmo bueno pa gozar |
10-16-2006, 04:12 PM
|  | Member | | Join Date: Aug 2006 Location: Somewhere between heaven and Mexico
| | Quote: |
Originally Posted by FloridaNative The PC dial just has whole numbers, 1,2, 3, 4, 5 and 6. there is no 5.5 marking. I just find mine by sound. I crank it up to six and then just tap it back some very slightly to where the sound changes. Regardless, if you run the PC at 5 or 5.5 it will still accomplish a beautiful finish. | I know it only has the whole numbers, but like Grimm said there is no inbetween speed, just a definite 5 or a 6, depending on which way you are dialing it, up or down. |
10-16-2006, 04:22 PM
| | Senior Member | | Join Date: Jul 2006
| | | Yeah that's what I was saying too... there is no 5.0, 5.1, 5.2... 5.5...5.8...6.0.
If you go to 5 and then go up until the sound changes... that's the same sound as 6. If you start at 6 and go down until the sound changes, that's the same as 5. |
10-16-2006, 04:24 PM
| | Quote: |
Originally Posted by Rapidity Yeah that's what I was saying too... there is no 5.0, 5.1, 5.2... 5.5...5.8...6.0.
If you go to 5 and then go up until the sound changes... that's the same sound as 6. If you start at 6 and go down until the sound changes, that's the same as 5. | Palabra.  |
10-16-2006, 04:41 PM
|  | Senior Member | | Join Date: Mar 2006 Location: Mass.
| | | there is no speed 5.5...lol...we discussed this on another forum and some one called PC and asked if there was a speed between 5 and 6...and answer was no...you go to speed 6 about half way from 5 and 6....
they were thinking of making it fully adjustable thru out the whole speed range..but never happened....
Al |
10-16-2006, 04:42 PM
|  | 24 HR Queue | | Join Date: May 2006 Location: Blue Ridge GA (The Mtns.)
| | | Wow.
Mine has a dial and has in between speeds. I have Meg's G100.....same as the 7424 but with a lifetime warranty.
Weird that yours don't. |
10-16-2006, 05:03 PM
| | Quote: |
Originally Posted by Al-53 there is no speed 5.5...lol...we discussed this on another forum and some one called PC and asked if there was a speed between 5 and 6...and answer was no...you go to speed 6 about half way from 5 and 6....
Al |
In between 5-6, on the dial, is 5.
Change the speed on your PC without it on and you'll feel "clicks" between 1-5 but none between 5-6. |
10-16-2006, 10:35 PM
| | Junior Member | | Join Date: Oct 2006
| | | OK , THATS ENOUGH , im gonna run it at 6. |
10-16-2006, 10:52 PM
|  | Senior Member | | Join Date: Mar 2006 Location: spring hill, Fl
| | | i choose 6 as well, anything less has always been 5 for me |
10-17-2006, 08:46 AM
| | I stand corrected. Learn something new everyday!
__________________ Oye como va mi ritmo bueno pa gozar |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
| | All times are GMT -5. The time now is 06:04 PM. |
