10-05-2006, 05:31 PM
|  | Junior Member | | Join Date: Oct 2006
| | | Okay, thanx everyone thus far, but there is one thing I don't quite understand about the Edge system. The center piece, how does it connect to the pad? Is there something in the center of the pad where the Adapter doesn't touch the part of the pad that contacts the surface of the paint?
I know its a simple question but I didn't see that in the explantion link.
__________________
3° Master Mason
PHA F&AM
10-05-2006, 05:42 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Mountville, PA
| | There is a video in the explanation link. It's located where the different pads and prices are shown. It explains and shows the system. Shows you the "backing plate" which is "sandwiched" between the pads and what the adapter locks into. http://www.autogeek.net/theedgebuffing.html
__________________
Alban B-)
2008 Ford F250 XLT 6.4L PSD, 4X4, SC, SB, Bedrug bedliner, Torza Trifold Tonneau cover, SS step bars / Dark Shadow Gray Metallic
2006 Nissan Sentra 1.8S / Inferno |
10-05-2006, 05:54 PM
| | | Okay, i'm sold on the EDGE system. Now, since I use Zaino Z-2 and Z-5, I only need two (white and blue) pads correct? I could use one to apply and take off the Z-5, and I could use the other to apply and take off the Z-2. Is this correct? Or should I just get the kit for $40 bucks more? (two pads and adapter = $60)
__________________
3° Master Mason
PHA F&AM
10-05-2006, 06:11 PM
| | | Instead of making a whole new thread, i'll ask here. When I am ready to remove the Z-5 (pro) residue after working it in with the PC, should I just use a micorfiber towel to remove it or a bonnet? The same question goes for the Z-2 (pro). I see that EDGE does not have bonnets in the link. However, after watching the videos, I was thinking that the Lake Country bonnets would work. Is this true?
EDIT** I just took another look at the EDGE kit ($100) and noticed it included 2 terry bonnets for removal. Looks like i'll get the kit after all!!!
Geez, you guys have been a lot of help and I want to thank you all! I'll post before and after pics of my next detail. (As soon as I get my pads, I am going to do my car again. I did it the first time by hand and micorfiber towels. This time i'll do it with the PC and EDGE pads!)
__________________
3° Master Mason
PHA F&AM
10-05-2006, 06:20 PM
|  | Moderator | | Join Date: Mar 2006
| | it's a great kit! i love mine. As for removal with a MF bonnet that's up to you. i haven't used the Zaino system, but when it comes to removal of any product for me, i just buff off by hand with a MF, but like I said it's your own personal preference.
__________________ Oye como va mi ritmo bueno pa gozar |
10-05-2006, 06:44 PM
|  | Senior Member | | Join Date: Mar 2006
| | Quote: |
| If you are just using the PC to only apply Zaino, then get the white finishing pad. Since you are not doing any paint correction, there is no need for anything other then a white finishing pad.
Now, if you are looking to do some paint correction in the future, I'd spend the money now and get a kit with a variety of pads. Quote: |
Originally Posted by Ankhenaton .....remove the Z-5 (pro) residue after working it in with the PC, should I just use a micorfiber towel to remove it or a bonnet? | Zaino is a pure sealant with no abrasives so there is no need to work it in...just thin, thin coats. Quote:
| Terry bonnets should work fine but I'd recommend MF over terry for removal via PC.
Good luck! |
10-05-2006, 07:23 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | Quote: |
Originally Posted by blkyukon Terry bonnets should work fine but I'd recommend MF over terry for removal via PC. |  |
10-05-2006, 09:36 PM
|  | Senior Member | | Join Date: Aug 2006 Location: Gaffney SC
| | Quote: |
Originally Posted by Ankhenaton Instead of making a whole new thread, i'll ask here. When I am ready to remove the Z-5 (pro) residue after working it in with the PC, should I just use a micorfiber towel to remove it or a bonnet? The same question goes for the Z-2 (pro). I see that EDGE does not have bonnets in the link. However, after watching the videos, I was thinking that the Lake Country bonnets would work. Is this true?
Geez, you guys have been a lot of help and I want to thank you all! I'll post before and after pics of my next detail. (As soon as I get my pads, I am going to do my car again. I did it the first time by hand and micorfiber towels. This time i'll do it with the PC and EDGE pads!) | You will be happy with the Edge kit. In the long run its cheaper! Two pads in one! |
10-05-2006, 10:11 PM
|  | Member | | Join Date: Sep 2006
| | | Checkout Adam's car polishes, they have edge pads with 2 diffrent pads on each side! you can polish and wax with 1 pad |
10-06-2006, 07:39 AM
| | Quote: |
Originally Posted by Emm Checkout Adam's car polishes, they have edge pads with 2 diffrent pads on each side! you can polish and wax with 1 pad | XMT and Poorboys SSR's will work as well if not better than Adams polishes. And we of course stock the Edge pads also. http://www.autogeek.net/theedgebuffing.html |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
