Featured Photos
by admin
531 photos
29 comments
by admin
Pinnacle Products
11 photos
20 comments
by admin
Exterior Gallery
65 photos
33 comments
by admin
Sema Show 2008
433 photos
13 comments
» Autogeek Car Care Products
Menzerna Polishing Compounds of Germany has set new standards for workability, uniformity, performance, and quality. Why else would Mercedes Benz use Menzerna polishes to perfect the finishes on their brand new vehicles?
Tags: , , , ,
Reply
Thread Tools Display Modes
  #21
Old 11-09-2006, 06:22 PM
ltoman's Avatar
geez, i think i bought mine from pinnacle.com. Will they still back it up if need be?
  #22
Old 11-09-2006, 06:27 PM
ltoman's Avatar
Quote:
Originally Posted by Tempered
Well, I spent 2 hours trying to find one in town with no luck so I got desperate and used some epoxy to glue it back on. If that doesn't work I will try to use the crappy white pad that comes with the PC. Although I dont have a pic I did a search and found someone had a similar problem. Although his was just starting to seperate mine had come completly apart. Basically the foam came loose from the plastic.
http://www.autogeekonline.net/forum/...5&d=1153668398
It was very hot when it came apart. I had been running pretty much non stop for a few hours (Corvette clearcoat sux btw). I picked up a shorter and heavier gauge ext cord in hopes that it will help keep the heat down.
Since I am leaving early Monday I will have to wait until I get back from my vacation to call. I will try to use my repaired backing plate tomorrow to finish up. Wish me luck!
Corvette clearcoat sux. Hmmm. How old was your vette? What did you use product/pad wise? mine is only 3 months old but I dont know what to start with and everybody says something different. i ordered all pinnacle stuff and lc pads.... ?? thank you
  #23
Old 11-09-2006, 08:42 PM
Quote:
I don't see why not, they are affiliated with Autogeek.
__________________
  #24
Old 11-10-2006, 09:39 AM
The clear coat on C5 vettes is very hard. I have even heard some say it is the worst on the 2001 - 2004 models (mine is an 02). I don't think it is as problematic on the C6.
I used the 3M line but was not really happy with it. It had a lot of dusting and I found out the line I bought contains silicates (a carcinogen). I plan to order the XMT series soon as a replacement.
I am also considering buying the Edge2000 pad system specifcally because I need to run the PC at high speeds and getting the LC pads perfectly centered is a PIA and I usually end up with a lot of vibration.
I would check with some C6 people here or at the corvette forum for your specific application, but I think your choice is good. Just start off with the least abrasive combo and work your way up until you find what works best.
Good luck!
  #25
Old 11-11-2006, 12:53 PM
sWISHbrade's Avatar
Quote:
Originally Posted by killrwheels@autogeek
we guarantee products offered by AG ... thus in most cases it would be replaced unless some tampering or physical evidence suggested something sinister. In most cases ... a simple replacement is mailed.
Hi,
My PC and BP + pads are is being sent to Singapore to me as we speak. May I know what are your replacement policies for international orders? Just in case...
Thanks
John
  #26
Old 11-11-2006, 02:54 PM
killrwheels@autogeek's Avatar
Moderator
I am sure we would take care of any issues ... that said, we pulled all the backing plates from that lot (believed to be the culprit) and returned to the manufacturer so should be no further issues.
  #27
Moderator
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Festool RO 150 FEQ users beware, backing plate flew off for two owners ZoranC Auto Detailing Forum 33 08-31-2007 10:43 PM
UDM Backing PLate Reddwarf Porter Cable 7424 & Buffing Pad Forum 6 08-22-2007 07:46 PM
Centering 6.5in pads on rotary backing plate HAN Porter Cable 7424 & Buffing Pad Forum 1 04-05-2007 08:41 PM
6" backing plate on PC?? BlackRocks Porter Cable 7424 & Buffing Pad Forum 10 10-06-2006 05:11 PM
small backing plate issue Neothin Porter Cable 7424 & Buffing Pad Forum 5 06-23-2006 10:00 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
