Featured Photos
by admin
531 photos
23 comments
by Meghan
Sema Show 2008
433 photos
6 comments
by admin
531 photos
23 comments
by admin
Exterior Gallery
55 photos
33 comments
» Autogeek Car Care Products
The Edge Buffing Pads
Tags: , ,
Reply
Thread Tools Display Modes
  #1
Old 08-13-2006, 08:21 PM
dengood1's Avatar
Question Backing plate melting?
Has anyone ever experienced a backing plate, or the velcro on it, melting in the center of the plate? I was detailing an Expedition today and when I went to apply more polish I noticed the pad was indented in the middle, kind of "sucked in" a little. I tried to pull the pad off and it was melted to the center of the backing plate! Sure, the PC gets hot when running at 6, but didn't think it would generate enough heat on the center shaft to melt the backing plate hook and loops! Has this happened to anyone else? Your thoughts?
Thanks!
  #2
Old 08-13-2006, 11:08 PM
joe.p's Avatar
Quote:
Thanks!
DG where you applying a lot of pressure or in one spot too long,I have had the velcro on the pads fail before but never seen a BP melt,sorry i couldn't help. someone from AG may have the answer dunno..
  #3
Old 08-14-2006, 12:19 AM
Neothin's Avatar
happens to me ALOT. occurs more often with small 4" pads, but i have melted a large backing plate before. If you continued to polish, it would've eventually had the yellow foam part melt and the whole backing plate would've ripped itself in half. happened to me many times. I can't figure out how to fix it besides turn the speed down, but you have to use speed 6 to polish, so im in a catch 22.
call jason in the morning and tell him that your having the same problem with the backing plate that i have. He'll help you out.
  #4
Old 08-14-2006, 06:11 AM
dengood1's Avatar
Does it happen less often using the larger pads and backing plate? I was using the low profile orange pad and I was doing a large vehicle.
  #5
Old 08-14-2006, 07:35 AM
Meghan's Avatar
Moderator
Thanks!
Dennis call Jason at his ext. (208) he will take care of you.
  #6
Old 08-14-2006, 09:03 AM
I know this has happened to quite a few hook and loop owners. My friend had his actually seperate at speed 5 and fly off. He has the Edge pads and his hook and loops just sit there now. I can do our suv's one after another at full tile (speed 6) and my Edge pads hold up fine. The shaft gets hot but the plastic inner seems to disipitate the heat.
__________________
The real WyStang:
  #7
Old 08-14-2006, 09:46 AM
SpoiledMan's Avatar
Sounds like you're using the wrong tool for the job. If you have to crank the PC up to a point that it's destroying BP's then it's time to pull out the rotary.
__________________
Black cars are easy!
  #8
Old 08-14-2006, 09:53 AM
Quote:
Except the PC can't do any real work with a polish or compound unless at speeds 5-6. I have Optimum Compound and Polish and they require speed 6 for a good break down and finishing up (but I have the Edge pads as well so...). Otherwise speed 3-4 I'll sit there all day with OC or OP with nothing happening.
__________________
The real WyStang:
  #9
Old 08-14-2006, 10:08 AM
SpoiledMan's Avatar
Quote:
That's why it's time to step up to something more powerful. In more than 2 years, I've only killed one BP on my PC and it wasn't melted or distorted at all but simply lost it's "grip."
__________________
  #10
Old 08-14-2006, 10:18 AM
Here is what your edge pad will look like if it self destructs. Jason has already replaced this for me... This is just to counter surfer's point that the edge pads are without reproach.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
5.5" pads-which backing plate??? lethalxls1 Porter Cable 7424 & Buffing Pad Forum 9 01-30-2008 04:22 PM
UDM Backing PLate Reddwarf Porter Cable 7424 & Buffing Pad Forum 6 08-22-2007 07:46 PM
Centering 6.5in pads on rotary backing plate HAN Porter Cable 7424 & Buffing Pad Forum 1 04-05-2007 08:41 PM
6" backing plate on PC?? BlackRocks Porter Cable 7424 & Buffing Pad Forum 10 10-06-2006 05:11 PM
small backing plate issue Neothin Porter Cable 7424 & Buffing Pad Forum 5 06-23-2006 10:00 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
