Back plate and pad for light polishing
Porter Cable 7424 & Buffing Pad ForumDiscuss Back plate and pad for light polishing in the Buffers and Polishers forums; Using the 7424HD what is the back plate and pad to use for light polishing using Menzerna 106FF and 85RD ...
Using the 7424HD what is the back plate and pad to use for light polishing using Menzerna 106FF and 85RD polishes.
Im basicly starting off with a freshly painted surface so really no correction is needed just up keep.
As far as a finishing pad to use with paste wax what size do you guys use?
For light polishing I use the 6 inch plate w/6.5 inch pads. If you need to do corrections medium-heavy, I would use the 4 inch pads w/3.5 inch plate. I just used the same polish on my car 106FA w/LC white and 85RD w/ LC blue.
