» Autogeek Car Care Products | | |  |
08-07-2008, 12:19 AM
| | Junior Member | | Join Date: Aug 2008
| | | How can I get the most out of my PC? I plan on doing some cars soon that may have minor to major swirls in them. What do you guys recommend as far as more products and pads? How can I make my pc work hardest on paint?
This is what I have now
6.5 orange
6.5 white
5.5 orangex2
menzerna sip
menzerna final polish |
08-07-2008, 01:17 AM
| | Senior Member | | Join Date: Apr 2008 Location: Rock Hill, SC
| | | Re: How can I get the most out of my PC? 4" pads, meguiars 95, 83, 82, 80
Prima Swirl
Danase Swirl Abolishers
Menz IP |
08-07-2008, 10:53 AM
|  | Moderator | | Join Date: Jan 2007 Location: Florida
| | | Re: How can I get the most out of my PC? Quote:
Originally Posted by BoredBuffer I plan on doing some cars soon that may have minor to major swirls in them. What do you guys recommend as far as more products and pads? How can I make my pc work hardest on paint?
6.5 orange
6.5 white
5.5 orangex2
menzerna sip
menzerna final polish | If you REALLY want to get that PC working more effectively, make the switch to 4" pads, with a 3.5" backing plate. You'll be able to generate more heat due to less friction/weight to bog down the motor, and in turn, will be able to remove more serious defects and break down polishes faster. Pick up a 3.5" backing plate, a few 4" yellow LC cutting pads for that SIP, and a few 4" green polishing/finishing pads for FP and you'll be set. |
08-07-2008, 07:15 PM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | Re: How can I get the most out of my PC? Edge kit and Menzerna polishes, the smaller heads as Matt offered above are also nice advice. |
08-08-2008, 12:52 AM
| | Member | | Join Date: Feb 2008
| | | Re: How can I get the most out of my PC? i have yet to switch over to the 4" pads. I keep hearing 4" or the 5" pads but i only see the 4" and 5.5" pads. I currently have 6.5" pads and as far as correction goes i was able to do a little correcting, but i'm sure like everyone else here states switch over to the 4". I'm going to just use the 6.5" for my Makita. |
08-08-2008, 07:51 AM
|  | Moderator | | Join Date: Mar 2006 Location: Florida
Originally Posted by vtec92civic i have yet to switch over to the 4" pads. I keep hearing 4" or the 5" pads but i only see the 4" and 5.5" pads. I currently have 6.5" pads and as far as correction goes i was able to do a little correcting, but i'm sure like everyone else here states switch over to the 4". I'm going to just use the 6.5" for my Makita. | I think everyone means 5.5" when they say 5", I know I find myself calling 6.5" six inch pads as well. But they are right the smaller the pad the more heat, equaling more results! |
08-08-2008, 12:24 PM
Originally Posted by Meghan I think everyone means 5.5" when they say 5", I know I find myself calling 6.5" six inch pads as well. But they are right the smaller the pad the more heat, equaling more results! | so it would be benificial to use the 4" pads then on the PC? When i initially baught my PC the detail supply place locally changed out the backing plate and i purchased some pads that they recommended, but after hanging around here the past several months i realized that the 6.5" pads they told me to use were just to big and no for correcting. I'm really thinking of making the change to the 4" would that be better or the 5.5" pads? |
08-08-2008, 12:41 PM
Originally Posted by vtec92civic so it would be benificial to use the 4" pads then on the PC? When i initially baught my PC the detail supply place locally changed out the backing plate and i purchased some pads that they recommended, but after hanging around here the past several months i realized that the 6.5" pads they told me to use were just to big and no for correcting. I'm really thinking of making the change to the 4" would that be better or the 5.5" pads? |
You can actually get the 3.5" backing plate, and while we don't recommend this on our site, I've had good results using that backing plate with both 4" and 5.5" pads. What you could do is use 4" cutting pads for heavier polishes, and use the 5.5" pads for lighter polishes that don't need as much heat to break down. (maybe some yellow 4", and green polishing/finishing 5.5") |
08-08-2008, 07:12 PM
Originally Posted by matt@autogeek.net You can actually get the 3.5" backing plate, and while we don't recommend this on our site, I've had good results using that backing plate with both 4" and 5.5" pads. What you could do is use 4" cutting pads for heavier polishes, and use the 5.5" pads for lighter polishes that don't need as much heat to break down. (maybe some yellow 4", and green polishing/finishing 5.5") | now you don't recommend using the 3.5" backing plate or don't recommend using the 4" pads and the 5.5" with the 3.5" backing plate? Sorry just making sure before i order. |
08-10-2008, 02:45 PM
|  | Member | | Join Date: May 2008
| | | Re: How can I get the most out of my PC? The 3.5" backing plate is an excellent choice with the 4" pads. Just used mine yesterday and had great luck cleaning up a beaten black hood, full of swirls and sap remnants (orange 4" w/Menz po91e). I believe what Matt meant was that this backing plate was not usually recommended for use with pads over 4" (althought he has done so with success).
Let us know what you choose to go with. |  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » November 2008 | | S | M | T | W | T | F | S | | 26 | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
