07-11-2008, 08:00 AM
| | Junior Member | | Join Date: Jul 2008 Location: Whitehall, Pennsylvania
| | | Re: Broken down polish Quote:
Originally Posted by Bence mgerencs, where are you from? | Pennsylvania, USA |
07-11-2008, 09:28 AM
|  | Senior Member | | Join Date: Mar 2006 Location: Hungary, Europe
| | | Re: Broken down polish Ah, thanks. Thought you were Hungarian, because Gerencs is a Hungarian name too.
Back to the original question. Breaking down means that the diminishing abrasives in a polish reach their final, extremely fine state, and they practically disappear. Their size is getting smaller and smaller, and after they performed the initial cut (while being in their original size), they break down into finer particles and do the final fine polishing of the surface, giving high gloss and great clarity. Heavier products, such as compounds usually contain macro abrasives (gritty feel between fingers), while other types, such as finer polishes contain micro abrasives (lotion-like). The abrasives (grit) are 'agglomerates' which break down to smaller, finer particles 'primary crystals' as they work. This can happen mechanically and/or temp-sensitively.
As you watch the trace of the polish, you can see that it gets finer as you progress with the procedure. When the polish is so fine that it is almost translucent, opaque - because the particles in it are now ever soooo small - this is the final state of its working cycle - the polish has broken down, and it is ready for removal.
Don't work them until they start to dust because dust particles can mar the finish. In the end, you will end up with less residue, easier removal. There is no firm timeframe for the working time of a given polish. Count in factors like outside temp., surface temp., humidity, pad type, pressure, machine speed, etc. In ceratin conditions the product can flash. Flashing means that a polish reaches an unwanted dry state very suddenly, often without completing its working cycle. |
07-11-2008, 04:15 PM
Originally Posted by Bence Ah, thanks. Thought you were Hungarian, because Gerencs is a Hungarian name too.
Don't work them until they start to dust because dust particles can mar the finish. In the end, you will end up with less residue, easier removal. There is no firm timeframe for the working time of a given polish. Count in factors like outside temp., surface temp., humidity, pad type, pressure, machine speed, etc. In ceratin conditions the product can flash. Flashing means that a polish reaches an unwanted dry state very suddenly, often without completing its working cycle. | Thanks Bence. That along with the other feed back clears it up for me. I appreciate all the help. |
07-17-2008, 09:33 AM
|  | Senior Member | | Join Date: Feb 2008 Location: Overland Park, Kansas, USA
| | | Re: Broken down polish If it's not too late for another question on this topic, does anyone have any tips on how to monitor the break-down progress on a WHITE care? I'm having a really difficult time on my white 560SL, and I tend to stop too soon when working on a panel because I can't really tell what's going on. Maybe I need to find some polish with some color to it! (wishful thinking, I know). Any feedback is appreciated.
__________________
Kevin Arburn
Overland Park, Kansas USA
1987 MB 560SL
2006 Mini Cooper S
2006 Scion xB
07-17-2008, 05:58 PM
| | Member | | Join Date: Jan 2008 Location: Massachusetts
| | | Re: Broken down polish get some halogen lights or more lighting towards that area |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » January 2009 | | S | M | T | W | T | F | S | | 28 | 29 | 30 | 31 |
