Quote:
Originally Posted by antekaudi Try to move PC more slowly. (that was my mistake)
You can try to go over same place 2 times.
If that doesnt help get something more agressive. |
It might help to check out the autogeek youtube DA polishing videos; they give you a pretty good idea about speeds. here is an example -
I am currently working on my wife's dark blue metallic '07 Si that has some pretty incredible water spot damage and spiderwebs from neglect, combined with the overall horrendously lame and soft Honda clear, so i'm working quite a bit slower and longer than what's in the vids, and i'm using Optimum's compound with an orange pad. I am being very cognizant of temperatures. I think the suggestions about speed are probably accurate for you too.
it's important also to check your work as you go along, and use some decent MF towels to remove product. i'd make sure the finish is where you need it before you apply any type of wax.
I hate to recommend you to spend more cash, but i have to say that Optimum's stuff is pretty awesome, affordable for the amount you get and it's simple to understand what you can use for what.
i fear that the stuff you are using might be useable, but contains stuff that will fill/hide as well as remove, so you might not get the true correction you are looking for, esp after some time goes by and it wears off from washing, weather, etc. what you've worked to remove, and thought disappeared, might reappear due to the hiding characteristics of alot of the OTC "scratch/swirl" stuff.
as far as Optimums stuff- orange pad for pretty much everything except final wax, compound for major stuff and hefty swirls, their polish as a follow-up to get the finish PERFECT and/or minor swirls, and then hand apply their sealant or i happen to use the Pinnacle SVN liquid. i like that their stuff doesn't fill or hide anything. it corrects, and...that's it. what you see is what's really there. i used the polish with orange pad on my mazdaspeed3, in a less aggressive manner than, say, what's on the video, and the finish is absolutely perfect. i mean, perfect.
i'm by no means an expert, and a real n00b on this forum (obviously), but i've been spending alot of time doing this and reading, so take it for what it's worth ; )
good luck.
