[Edge 2000 pads] Question
Porter Cable 7424 & Buffing Pad ForumDiscuss [Edge 2000 pads] Question in the Buffers and Polishers forums; http://www.autogeek.net/vcpad.html
pad info..........
for you about the cutting powers of each pad....maybe it will help you understand each pad ..im still learning also and always go to this guide when im not sure of each pads ability.......
Wrong pads bro... I am using the edge 2000 pads. And I know what the desc says about them, I even quoted them at the top I was just wondering real world what the real diff was between the two.
sorry.. .... i often thought that same question between the grey and blue..... they seem very similar to me.....
anyway, the edge guys will tune in soon to answer your question
good luck anyway........
Oh, all my belongings are wille dot my dogs!
I should see about getting a replacement.
Both of our DA's are new (mine was replaced for me recently) so maybe this is lubricant coming out of the DA. Ordinarily the backing plate prevents that??? but there is no backing plate with the E2K.
The blue pad is really and every day polishing pad. The white pad is softer and is reserved for dark colors and exotic cars that are kept in very good shape all the time. If the surface is not perfectly smooth the white pad can sometimes be too soft and dry the product on the surface and leave spots. The blue pad will not scratch but has enough texture to remove the product and leave a clean surface all the time. We do notice a higher and deeper gloss on dark colors when using the white pad, but only a very discerning eye would notice.
