| Re: LC pad problem... HELP! Is this after use, or the way they came in
They're foam, so they tend to form around anything they're pressed against
That said, if that's the problem then just hook them on your PC, spritz a bit of water, or QD if you're ready to use them, and spin them up for a few seconds at 3. That should make them "pop" back into form
There are some pads that are flat, and others have a concave surface, which if this is your case, then that's just the way the pads are...
__________________ -Goose 2002 Z06 Bone Stock 2001 ZR2 Bone Stock ------------------------------------------------- Free Our Troops! |
