05-17-2008, 07:02 AM
|  | Junior Member | | Join Date: Jul 2007 Location: Coral Spring, Fl
| | Pads and Speed Need some help from all the knowledgeable people in here. I got my PC earlier this week (was finally able to afford it, nothing wrong with AG) along with a few orange pads (CCS I believe). I also found in here a "pad chart" with LG pads in an "aggression scale". One question is - Are the pads "aggression" basically the same between LG and CCS? Second question is - At what speeds do I set my PC? The package didn't say anything except that 1-2500 OPM and 6-6000 OPM. And there is nothing on the comparison chart about which speeds to use with which pads. I 'm looking to mark my chart with the speeds so that I don't mess up any thing.
Any and all help is welcome.
Thanks in advance.
__________________ Perfessor
2003 Eclipse Spyder
Convertible |
05-17-2008, 07:34 AM
|  | Moderator | | Join Date: Mar 2006 Location: South Florida
| | | Re: Pads and Speed pads abrasiveness and coloring are somewhat unique to each manufacturer, no industry standard.
For polishing use PC on 5.5 - 6 on dial, if removing wax with bonnet use around 3, and turn on low when spreading wax and polish. |
05-17-2008, 07:53 AM
| | | Re: Pads and Speed Quote:
Originally Posted by killrwheels@autogeek pads abrasiveness and coloring are somewhat unique to each manufacturer, no industry standard.
For polishing use PC on 5.5 - 6 on dial, if removing wax with bonnet use around 3, and turn on low when spreading wax and polish. | Bonnet? Bonnet! Damn, I knew I forgot something in that order!
Back on topic - So the LC orange pad is more or less "aggressive" than the CCS orange? And do you know of a chart for the CCS pads?
2003 Eclipse Spyder
Convertible |
05-17-2008, 09:07 AM
|  | Senior Member | | Join Date: Dec 2006 Location: Central Ca. (Hwy to Sequoia)
| | | Re: Pads and Speed 2-3 to spread
5-6 to work polish
I use 4 for glazes |
05-17-2008, 09:39 AM
Originally Posted by Jimmie 2-3 to spread
5-6 to work polish
I use 4 for glazes | Is wax considered a glaze?
2003 Eclipse Spyder
Convertible |
05-17-2008, 09:50 AM
Originally Posted by Perfessor Is wax considered a glaze? | No, they are different. I wax with hand application but if I were to use the PC I'd probably spread wax at 3-4. |
05-17-2008, 04:52 PM
|  | Senior Member | | Join Date: Jun 2006 Location: Central Florida
| | | Re: Pads and Speed glaze has little or no protection.....adds gloss and hides swirls. Wax protects, hence LSP (last step process). Both done with softest pad (black or blue usually) on speed 3. |
05-17-2008, 04:54 PM
Originally Posted by Perfessor Back on topic - So the LC orange pad is more or less "aggressive" than the CCS orange? And do you know of a chart for the CCS pads? | I believe they're the same. |
05-17-2008, 10:24 PM
| | | Re: Pads and Speed So the procedure would be polish, glaze then wax?
2003 Eclipse Spyder
Convertible |
05-17-2008, 10:38 PM
Originally Posted by Perfessor So the procedure would be polish, glaze then wax? | Yes... |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » August 2008 | | S | M | T | W | T | F | S | | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
