poorboys world professional polish
Porter Cable 7424 & Buffing Pad ForumDiscuss poorboys world professional polish in the Buffers and Polishers forums; first time using the 7424 ,just wondering if I should use the CCS Gray or Blue pad for applying this ...
first time using the 7424 ,just wondering if I should use the CCS Gray or Blue pad for applying this polish?Thanks
Most polishes work well with the white pad. If it doesn't remove the swrils or marring then move up to an orange pad. Gray, blue and red are for applying waxes or sealants or for jeweling the paint.
the poorboys professional polish can be used fine with the gray pad...if you desire a little cut then get the white pad, but the gray will do just fine....
PB pp is for cleaning the paint before waxing or sealing ? am i right
It'll do a lot depending on the pad you use ... a polishing or finishing pad will clean the paint and leave a great base for any wax or sealant and used with a rotary and wool pad, it'll cut through sanding marks ... PB Pro Polish- A versatile chemical polish
Ok so if I used the LC white pad then I would be doing some paint correction and polishing at the same time ? So after I did that I could go right to LSP
