Re: Edge2000 Orange/Green Pad The orange and green pads are stiff because they are cutting pads. I have the Edge 2000 set that came with the rotary adapter. Also, check your yellow pad, it should be stiff also, mine is. The other pads in your set are not supposed to be stiff. I will admit, the green pad does fell softer than the orange pad, i found that to be a little odd. |
