Quote:
Originally Posted by fech I use the edge pads which I believe are 5 inches. I'm not trying to sound dumb, but how does it work if it's not spinning the pads? |
The pad is not vibrating it is spinning off axis - orbiting around the axis, making a small circle as it goes around the center.
I agree with
Surfer that the spining doesn't aid in the polishing - the pad doesn't spin fast enough to do any benefit...In fact, it's slow enough at times I can count the revolutions of the spins.
With that being said though, it should spin at least a little especially at speed six. What speed are you running the PC at?
Try placing a piece of tape on the back side of the pad and see if there is any centrifugal rotation at different speeds and pressure.
