Featured Photos
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by admin
Sema Show 2008
433 photos
6 comments
by admin
531 photos
23 comments
» Autogeek Car Care Products
Porter Cable 7424 & Pad Kit with CCS pads!
Reply
Thread Tools Display Modes
  #11
Old 03-30-2008, 11:38 PM
wytstang's Avatar
Re: FLEX + Extension cord
If you are repairing wire you should solder wire to make it a "whole" again. Twisting wire and taping it or capping them leaves breaks in the wire making them "jump or arc" to the next wire. This causes resistance making the wire hotter and taking away power/juice to whatever is asking for juice. Many times machines start to run hotter because they are fighting to get power and handle the work load. Having the proper extension cord to match the machine being used keeps them running strong and cooler. Since buffers are hard at work for 4+ hours having a good extension cord plays a large role. Now if you are using a machine on and off for just an hour a patched up cord would work, since the demand is low and there is a cooling period. But it is always best and recommended that cord matches the machine for optimal operation.
__________________
Surfer Caught on tape
  #12
Old 03-31-2008, 05:35 AM
TOGWT's Avatar
Prime Wire & Cable Duplex GFCI (Ground Fault Indicator) Junction Box with 6-Ft. Cord, Model# GF200806 Portable GFCI duplex receptacle detects power leaks and shuts off electricity in less than a second to prevent shock. Test and reset buttons Tough jobsite box with 6-ft. 12/3 SJTW power cord UL listed, meets OSHA standards.
Prime Wire & Cable 50-Ft extension 12/3 Neon Power Cord — Blue, Model# NS514830
Bright NEON extension cord stands out for easy identification. 12 Gauge, SJTW, 3 prong cord features super-flexible vinyl jacket with a cold temperature rating of -31°F. LIGHTED connector indicates when power is on. Cord is water and flame resistant and rated at 15 amps, 125V, 1875 watts, UL listed and meets OSHA standards – Northern Tool Co - Portable Generators, Heaters + Wood Stoves, Snow Blowers, Pressure Washers | Northern Tool + Equipment
  #13
Old 03-31-2008, 05:36 AM
TOGWT's Avatar
  #14
Old 04-08-2008, 10:32 AM
trlblazer3's Avatar
I picked up a 100' Rigid 12 ga. contractors grade a few months ago -works like a champ. Main use will be for my halogens and my Durrmaid.
__________________
  #15
Old 04-08-2008, 02:52 PM
I prefer 12 gauge from the main, but I usually use a 14 gauge 25 footer connected between that and the 12awg extension cord.
14awg is just lighter and more flexible.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Extension for Flex........ YankeeFan Auto Detailing Forum 11 02-08-2008 05:05 PM
Review of Flex XC3401 VRG wolfpacker92 Flex Polishers 38 11-16-2007 09:58 PM
Will this extension cord work with my porter cable with no problems? Conor Porter Cable 7424 & Buffing Pad Forum 5 05-04-2007 07:43 PM
How-To: Rotary Cord Extension justin30513 Auto Detailing Tools and Accessories 12 03-18-2007 08:24 PM
Extension Cord gandblah Porter Cable 7424 & Buffing Pad Forum 8 12-07-2006 07:29 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
