Featured Photos
by admin
531 photos
29 comments
by admin
Sema Show 2008
433 photos
13 comments
by Meghan
Sema Show 2008
433 photos
13 comments
by admin
531 photos
29 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Reply
Thread Tools Display Modes
  #11
Old 03-27-2008, 07:53 PM
Re: Flex and pad question?
Quote:
Originally Posted by Al-53 View Post
Zoran...it can be done by any one really....I seen one that a guy did with a dremel and a cut saw blade ..he just followed the ring and cut just the plastic area and cut the foam and velcro with a razor...looked perfect...
I'm too much AR to do it simple way, I want the lathe
But on the other hand you are giving me idea, Dremel based router should be able to trace it perfect. On the other hand I have one of those temporary 5" plates around so I am using that in the meantime.
  #12
Old 03-27-2008, 07:54 PM
Quote:
Originally Posted by k20z3kid View Post
hmm whats wrong with using 5.5" pads with a 5.5" backing plate??
Nothing as long as you are not getting edge of pad close to paint. Which you shouldn't be doing to start with.
  #13
Old 03-27-2008, 08:08 PM
Al-53's Avatar
Ok..mine was cut on a bridgeport..I said lathe before but it was a bridgeport..the center hole was used to rotate it while bolted to the table...the plate was then rotated under the cutting tool...to the point it hit the foam......then cut with a new razor..took all of 10 minutes...
Al
  #14
Old 03-27-2008, 09:09 PM
What is a bridgeport?
  #15
Old 03-27-2008, 09:20 PM
Al-53's Avatar
Zoran..it's a milling machine..sorta looks like a drill press but it uses Milling bits in stead of a drill...its for precesion cutting of metals...
looks like this...the table can raise 1/1000th of a inch if needed...
Mills
Al
  #16
Old 03-27-2008, 09:39 PM
MadOzodi's Avatar
I think I'll just stick to the 6.5 & 7.5" pads
__________________
07 Cosmic Blue Mazdaspeed3
00 Black Mustang GT - Spring Ed. (for sale)
  #17
Old 03-27-2008, 09:55 PM
Mills
Swweeeet! I want one!
  #18
Old 03-27-2008, 10:37 PM
I have bought 2 extra plates and I had one cut down to the support ring and its a little over 4.5 inches now and I use my 5 and 5.5 in pads no problem....and have not seen a issue with the smaller plate...I just used it today infact for 3 hours on paint and it did just fine...in fact I ithink it has less issues with it flexing like some had and had it scraping....but that may have been a loose mounting screw also..but any ways it works fine and I use all my pads now
Al
Al-53, if you dont mind me asking, can you take a picture of the pad that you reduced to 4.5 inches. I'm a bit worried with the 5.5in pads also and i bought like 3 of each color. I might get some sonus 6in pads also.
-Sam
  #19
Old 03-27-2008, 10:49 PM
_M_'s Avatar
_M_ _M_ is offline
Al
Al,
where did you buy your backplates from please?
  #20
Old 03-28-2008, 12:34 AM
wytstang's Avatar
Thanks for the info, I'll think about it
__________________
Surfer Caught on tape
Surfer after months of icing down your........how do you feel?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
EDGE pad system for FLEX? maiku Auto Detailing Tools and Accessories 7 03-20-2008 12:49 AM
Another Flex Review Excessive Detail Flex Polishers 23 02-25-2008 10:04 PM
MY FLEX Fling and review Ray in Kingwood Auto Detailing Forum 18 02-25-2008 12:27 PM
Foamed wool pad with the flex? redg35 Porter Cable 7424 & Buffing Pad Forum 9 12-13-2007 01:24 PM
Review of Flex XC3401 VRG wolfpacker92 Flex Polishers 38 11-16-2007 09:58 PM
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
