Quote:
Originally Posted by imageautodetail Seems to be the general concensus, I will have to order some and try it out...Thanks to all who responded |
No problem. If you've used Optimum's other polishes, you probably already know less is more. Once your pad is primed, you only need a couple pea sized dots per panel. Another thing to know is that PS will vanish into the paint as soon as you apply it. Don't mistake this for it "not working". As long as your pad is gliding over the paint, PS is there and it is working. You'll be left with next to nothing to buff off. Good luck!
