Featured Photos
by admin
531 photos
29 comments
by admin
Sema Show 2008
433 photos
13 comments
by admin
Sema Show 2008
433 photos
13 comments
by admin
531 photos
29 comments
» Autogeek Car Care Products
Meguiars G110 Polisher
Reply
Thread Tools Display Modes
  #11
Old 02-08-2008, 07:47 AM
Re: Help!!
I've got a question too. I got the UDM instead of the PC and my backing plate was already installed. Am I good to go or do I need to adjust or do something to it before I use it for the first time?
  #12
Old 02-08-2008, 12:58 PM
blk45's Avatar
Re: Help!!
Quote:
Put on a pad and have at it.
  #13
Old 02-09-2008, 12:46 AM
Member
Re: Help!!
my PC when I put it at 6 it start shaking real hard, I noticed that this is why my BP broke. It almost happened again with my new BP, I must used it at 5 and I have the spacer
  #14
Old 02-09-2008, 04:43 PM
Rsurfer's Avatar
Re: Help!!
Quote:
How did you get a new BP so quickly?
  #15
Old 02-09-2008, 05:55 PM
Member
Re: Help!!
paint shop
  #16
Old 02-09-2008, 06:10 PM
Brian_Brice's Avatar
Re: Help!!
Sometimes I wish my pc would die, I've dropped it in water, on the ground many times, nothin'. Putting it to scrub work won't even break this tool.
  #17
Old 02-09-2008, 06:44 PM
lethalxls1's Avatar
Re: Help!!
Marchese- I wouldnt use the PC on level 6. Level 6 is going to vibrate and shake alot no matter what. I never run my PC above 5 EVER for this reason and because the polish dries way too fast and doesnt give you enough time to work the polish. Also- I dont have a washer on my PC and it works fine.
__________________
98 Z/28
  #18
Old 02-09-2008, 06:51 PM
budman3's Avatar
Re: Help!!
A rotary creates friction and the heat generated from the friction gets directed right down onto the paint. A PC is the opposite, the friction geneates heat and that heat goes straight up into the backing plate. If the pad does not freely spin it is either because the pad isn't flat on the surface, you are applying way too much pressure or there is an increase in friction due to the missing spacer. So if one of these three things occured while using the PC, is most likely the cause of the BP failure. It looks to be that the BP heated up a lot, softened a little and the threading came out.
  #19
Old 02-09-2008, 07:12 PM
lethalxls1's Avatar
Re: Help!!
^ That is very true- when I change pads on my PC I always notice the backing plate is extremely hot.
__________________
98 Z/28
  #20
Old 02-09-2008, 11:01 PM
Member
Re: Help!!
I used the menz at 5, and if you want pics go to the show n shine forum
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
