Featured Photos
by Meghan
Autogeek's 2nd Annual Detail Fest
40 photos
16 comments
by Meghan
40 photos
16 comments
by Chopperguy
Motorcycles
4 photos
1 comments
by admin
Sema Show 2008
433 photos
13 comments
» Autogeek Car Care Products
Ice Master Multi Blade ice scraper
Reply
Thread Tools Display Modes
  #1
Old 02-03-2008, 07:06 AM
PC and Menz
Will the menz. intensive polish(po91E) and Final polish (po85u) or the nano polish (po106ff) work very well with the porter cable. I have been using xmt products, but thought I would try the menz. Just not sure which menz. products to buy for daily drivers
  #2
Old 02-03-2008, 07:15 AM
justin30513's Avatar
24 HR Queue
Re: PC and Menz
Quote:
They will work with it but not as well as with a rotary. This is what they were designed for. The PC cannot generate enough heat to break down the polish/compounds correctly.
You will need to add a lot of pressure and take your time. Try not to use them on a cool, humid day either.
These are just my experiences.
  #3
Old 02-03-2008, 08:36 AM
ASPHALT ROCKET's Avatar
Re: PC and Menz
They can be used with the pc and will give you better results, if you want the best results from Menzerna a rotary is needed.
As far as alot of pressure as said above, I don't find that to be true, it is more of finding the right pad combo with the polish.
  #4
Old 02-04-2008, 03:31 PM
Andy Wayan's Avatar
Re: PC and Menz
yeah..am sometimes on PC with Menzerna...it will work..like Asphalt Rocket had mentioned u do need lots of time..
however having said this..thinking of getting the Makita 9227c for cutting..and the PC for buffing...
__________________
Carnauba is my way
  #5
Old 02-04-2008, 05:13 PM
budman3's Avatar
Re: PC and Menz
I could use the Menzerna Intensive all day with a rotary with no problem at all... but on a PC it'll almost instantly dust on me, which wouldn't happen when using a rotary for some reason. I tried less product, more product, working it in longer, etc ... not fun with PC. Final polish doesn't correct much with a PC either. However Nano 106ff is a lot more user friendly than the IP / FP combo, IMO.
  #6
Old 02-06-2008, 10:47 PM
Mr Dream Machines's Avatar
BANNED
Re: PC and Menz
I can break down any of those by hand so it's not a problem
Heck even Prima Cut will break down perfect for me by hand.
About four minutes to do that by hand but will take out swirls no probs.
  #7
Old 02-06-2008, 10:52 PM
Smith2287's Avatar
Member
Re: PC and Menz
I used the menz line up with the PC and it broke down just took some time. When I tried it with the Flex it was much faster, and I was amazed!!
__________________
Corey Smith
  #8
Old 02-06-2008, 10:56 PM
MotorCity Honda's Avatar
Re: PC and Menz
Menzerna has worked fine for me with PC... Of course due to the power of the rotary it will break down ANY polish faster.. But do not fear Menz and PC play very well together
I have never had to apply an unusual amout of pressure...
  #9
Old 02-07-2008, 01:50 AM
lethalxls1's Avatar
Re: PC and Menz
^ I agree Dont find much pressure ness. at all-usually a little more than the weight of the PC. If you have been using XMT with a PC and you try the Menz with a PC you will never use the XMT again.
__________________
98 Z/28
  #10
Old 02-07-2008, 07:26 AM
killrwheels@autogeek's Avatar
Moderator
Re: PC and Menz
All of these polishes can work successfully with a PC. The side effect to a ROB is that it takes alot more time to correct properly, and pad/polish choice dictate how much can be done. That said, for the hobbist it usually is the safer choice and can actually be fun once you get the hang of the machine. Higher speeds, and time is needed.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
» January 2009
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
