Hey all,
Thought I'd show a case I put together for my G100. Someone suggested I make a slot to keep the back plate on, and that's a good idea.
Lowe's has aluminum sided cases with cube foam for around $25.00, but the one I used is a molded case I got on eBay.
Just line up your items on the foam as you'd like them to be stored, then tear out individual cubes from the foam to snug the item into. Leave room for other items you might want to add later, possibly different size backplates.
