A little update. I had contacted AG and was about to ship the UDM. Before I shipped it out I decided to give it one more try and it started right up...While it was running I started to put the back cover back on and it stopped again..removed the cover and it came back on. What I have found is that the red wire going to the speed selection switch is to short and has put to much stress on where the wire is going into the speed switch. So it appears that it is causing the speed switch to randomly short, during the vibrations the wire is pulling itself out of the speed switch. Watching closely while trying to put the back cover on while the UDM is running I can see a spark of some sort coming from where the red wire is going into the speed switch. Easy fix, but I feel like this isn't something that is or should have been easily overlooked. Not to mention possibly dangerous. And while I could get a new whole unit I can't really afford to be sitting around without a buffer..So it looks like this will be a DIY fix..probably get a new switch also. It is a nice machine but at the same time I was expecting a little more then what it is really offering. |
