10-31-2006, 04:50 AM
|  | Senior Member | | Join Date: Mar 2006
| | XMT refills - larger sizes? Will Pinnacle XMT series swirl removers be available in larger then 32 oz refills? More ounces for the buck.
Just wondering?
__________________
1997 Acura 3.2 TL (sold)
2004 BMW 325 Ci jet black(girlfriend's car).
10-31-2006, 08:34 AM
|  | Moderator | | Join Date: Mar 2006
| | | I would love to see that too!
__________________ Oye como va mi ritmo bueno pa gozar |
10-31-2006, 09:46 AM
|  | Senior Member | | Join Date: Oct 2006
| | | Not to go OT but sorta the same....
I wouldnt mind seeing XMT pad cleaner and conditioner available by the gallon as well. That would be nice.
__________________ ----2002 35th Anniversary SS Camaro Limited Edition---- --------------------568rwhp/551rwtq--------------------- -D1SC Procharger-Custom Cam-FMIC-6.0L Heads-11psi- |
10-31-2006, 10:30 AM
|  | Senior Member | | Join Date: Oct 2006 Location: Dayton, OH
| | | I'm about to order the XMT series... How do you all like it? Is the #3 very good at polishing out the deeper swirls and such? Or is there a better compund you recommend? |
10-31-2006, 11:42 AM
| | Senior Member | | Join Date: Apr 2006 Location: Boca Raton, FL
| | Quote: |
Originally Posted by Avengeance Not to go OT but sorta the same....
I wouldnt mind seeing XMT pad cleaner and conditioner available by the gallon as well. That would be nice. | Pad Cleaner and Conditioner in gallon size would be great!
__________________
The real WyStang: |
10-31-2006, 12:24 PM
|  | Senior Member | | Join Date: Oct 2006 Location: Hendersonville NC
| | Quote: |
Originally Posted by Whitethunder46 I'm about to order the XMT series... How do you all like it? Is the #3 very good at polishing out the deeper swirls and such? Or is there a better compund you recommend? | #3 XMT is great give it a try first then hit it with XMT 1 |
10-31-2006, 02:04 PM
| | I love the XMT 3!! Look at this picture of this VW bug. Half of the door and the fender had been done in XMT 3 and the other half was unpolished.
10-31-2006, 02:09 PM
| | Quote: |
Originally Posted by FloridaNative I love the XMT 3!! Look at this picture of this VW bug. Half of the door and the fender had been done in XMT 3 and the other half was unpolished.  | wow, that's amazing. Looks like you used the orange pad?
And did you go straight to a glaze after that, or did you use #1? |
10-31-2006, 02:22 PM
| | Quote: |
Originally Posted by Whitethunder46 wow, that's amazing. Looks like you used the orange pad?
And did you go straight to a glaze after that, or did you use #1? | Yes. This car had clear coat failure in several places so I had to treat it gently. I used XMT 3 with the orange pad on the entire car, followed by XMT 1 and the polishing pad and finished it off with the XMT carnauba finishing glaze applied with the finishing pad and then Souveran paste wax. Here it is after I finished the detail.
10-31-2006, 02:42 PM
| | | That's absolutely gorgeous. Is it recommended to use the #1 after the #3 usually? Or is it safe to go straight to the glaze after the #3? |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » August 2008 | | S | M | T | W | T | F | S | | 27 | 28 | 29 | 30 | 31 |
| 1 | 2 | 3 | 4 | 5 | 6 | |
