Results 1 to 4 of 4
    Jul 2016
    3,328
    Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba
    hi so i was wondering is the concentrate when diluted the exact same as the stuff you can buy pre mixed in a pinnacle bottle or is there a difference at all? i was going to buy the premixed stuff for twenty but the concentrate is a much better deal with the towels and stuff ill prob get that
    Super Member Cruzscarwash's Avatar
    Oct 2015
    Desert of California
    2,425
    Re: Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba
    You can mix it to be the same or stronger it weaker, your choice, thays what makes concentrates so great is that you can dilute for different purposes if you wanted to. Thats why everyone is so upset over d114 going away
    Aug 2014
    1,445
    It's the same stuff. Just know that there's so much carnauba wax in it that you will need to dry it thoroughly or you will have spots on glass. It's what I use, and it's very good stuff.
    "I've seen a good quality car wash look better than some guys complete detail jobs."
    Mike Phillips 10/21/09
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    OP...Put your mind at ease:
    Manufacturers have Chemists that have
    not only formulated these concentrated
    products ("stock solutions"), but have
    taken out most of the dilution guesswork
    by also including the calculated dilution
    ratios for the end users' convenience.
    Note:
    The formula for determining the amount
    of a "stock solution" (at a known strength)
    that's needed to make a diluted solution
    (at the desired amount and strength) is:
    Q1 X C1 = Q2 X C2
    Where:
    Q = quantity
    C = concentrate
    (quantity1) X (concentration1) =
    (quantity2) X (concentration2)
    All that's left is to: plug in the
    numbers; and, solve: by the
    inverse proportion methodology.
  1. Pinnacle Liquid Crystal Waterless Wash Concentrate?
    Last Post: 12-25-2016, 04:58 PM
  2. Replies: 17
    Last Post: 12-18-2014, 02:40 PM
  3. Pinnacle's Liquid Crystal Waterless Wash w/Carnauba
    By addysdaddy in forum New Car Care Products
    Last Post: 12-14-2012, 09:31 AM
  4. Replies: 9
    Last Post: 12-01-2012, 12:50 AM
  5. How To Use Pinnacle Liquid Crystal Waterless Wash with Carnauba
    By Mike Phillips in forum New Car Care Products
    Last Post: 11-15-2012, 09:17 PM
