Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree3Likes
Thread: Need help with Pinnacle black diamond surface coating
    Senior Member Rsurfer's Avatar
    Jan 2007
    10,066
    Re: Need help with Pinnacle black diamond surface coating
    d
    Quote Originally Posted by Mantilgh View Post
    If you are doing the "Sealant" you should be fine.
    It would probably also be fine too if you meant the "SurfaceI Coating" product that is being discussed here.
    The Lake Country Coating Applicator is what is recommended on the product page for the Surface Coating.
    Is this a true coating. If it is, how durable is it, if you can remove high spots with a QD after it has dried?
    Jul 2013
    d
    A good question i too would like to know the answer to. I don't think this stuff is going to last "years" if you can wipe off high spots with a spray of quick detailer a week or more later. (And you definitely can... I just did it myself.)
  3. #13
    Senior Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,205
    Quote Originally Posted by joeybsyc View Post
    Just an FYI, the BL QD is more than just a regular QD. It seems like a watered down version of the booster - so it has some active ingredients in it, which would be ingredients that are soluble in whatever solvent the QD uses as a base. I haven't used the QD - but a bottle is coming my way in the mail any day.
    It seems to me PBL Coating is loaded with IPA. It just reeks of IPA. So, it could be the IPA in the QD (I'm guessing it's in there) that knocks down the high spots.
    On another note, before polishing anything, I've found simply applying more of the coating on a MF towel and buffing it down levels high spots. However, this is shortly after the coating is applied. I'm not sure how long after application this technique will work. On the other hand, I would always try this method or straight IPA before re-polishing. My guess it will work for a while.
    Just because the coating is able to be knocked down by the QD, doesn't mean it's not really a "coating". Certain solids are dissolvable in certain solvents. Something soluble in some IPA isn't necessary soluble in water (think rain).
  4. #14
    Jul 2013
    Quote Originally Posted by swanicyouth View Post
    Well, what if I told you I used regular old water based QD with a microfiber towel a week later and it knocked the "high spots" right down?
  1. Pinnacle Black Label Diamond Surface Coating Removal?
    By dizzyscure1 in forum Ask Mike Phillips your detailing questions!
    Last Post: 12-02-2014, 11:48 PM
  2. Feedback on those who have tried Pinnacle Black Label Diamond Surface Coating
    By DeepShine69 in forum Ask Mike Phillips your detailing questions!
    Last Post: 02-18-2014, 04:10 PM
  3. Review: Pinnacle Black Label Diamond Surface Coating
    By Bryan@Autogeek in forum Product Reviews
    Last Post: 01-07-2014, 10:42 AM
  4. Replies: 2
    Last Post: 11-08-2013, 04:09 PM
  5. Replies: 7
    Last Post: 11-03-2013, 06:34 AM
» April 2017
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
