Go Back   Auto Geek Online Auto Detailing Forum > Auto Detailing Forums > Off-Topic
Featured Photos
by admin
Sema Show 2008
433 photos
6 comments
by admin
531 photos
23 comments
by admin
531 photos
23 comments
by Meghan
Sema Show 2008
433 photos
6 comments
» Autogeek Car Care Products
Porter Cable 7424 & Pad Kit with CCS pads!
Reply
Thread Tools Display Modes
  #1
Old 08-16-2007, 01:57 PM
Member
Removing badges.
I'm going to remove som badges from my car. How can I do this the easiest and safest way without harming my paint?
  #2
Old 08-16-2007, 02:03 PM
MotorCity Honda's Avatar
It's very easy..
Just use fishing line and get between the paint and the badge and shave it off.
Some adhesive may be left on the paint and I use a steamer to safely/effectively remove.
Some badges have pins holding them in and can't be removed by this method. If you do remove the badges with pins they will leave holes in you body where the pins were.
  #3
Old 08-16-2007, 02:11 PM
Member
Ok, thanx for the answer But I dont have a steamer. Do you got any other things to recommend?
  #4
Old 08-16-2007, 02:15 PM
LazerRed1's Avatar
Use 3M Adhesive Remover to take off tape that is left.
  #5
Old 08-16-2007, 02:25 PM
Al-53's Avatar
wear gloves...I have seen fishing cut right into a hand....use something like 20 pound test...either 3M adhesive remover or wd40 will take the adhesive off..
AL
  #6
Old 08-16-2007, 02:28 PM
Mike T's Avatar
I used a blow dryer, fishing line, & Goo Gone.
  #7
Old 08-16-2007, 02:33 PM
LazerRed1's Avatar
Goo Gone will work, eventually. The 3M AR is mich quicker and is actually designed just for that purpose.
I removed almost all of mine as well as side door guards.
  #8
Old 08-16-2007, 03:24 PM
GearHead_1's Avatar
A heat gun or blow dryer and dental floss (slightly less abrasive than fishing line should one slip when performing the procedure) has worked well for me. One thing to take into consideration is to check and make sure that the badge being removed doesn't have any protrusions that go through the sheet metal prior to removal. I've see many badges that have alignment holes behind them. It wouldn't be any fun to remove a badge only to find that you need to put it back on to cover alignment holes. WD-40 works quite well at removing any of the remaining double sided tape.
I hate badges! It's great to have a vehicle with no identifiers left on it. It's amazing how many people don't know what you are driving when there's no logo on the vehicle particularly if the vehicle has been customized to some degree.
__________________
When it comes to a persons worth, money is a lousy way to keep score.
-GH-
  #9
Old 08-16-2007, 04:46 PM
Member
Thanks guys, I will try those tips you gave me Can't find 3M AR at Autogeek
  #10
Old 08-16-2007, 05:43 PM
killrwheels@autogeek's Avatar
Moderator
toothfloss tripled over, use a light back and forth motion. Cleanup with Goo-Gone, Wd-40, or a dozen other paint cleaners. Alcohol works in a pinch on minor glue.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Body all purpose cleaner or solvent for removing wax? Cobra04 Auto Detailing Forum 16 08-12-2007 07:08 PM
removing swirl marks jon c Auto Detailing Forum 3 07-19-2007 11:15 AM
Imprompt Poll -- Should AG consider removing Off-topic ?? killrwheels@autogeek Off-Topic 36 04-06-2007 05:27 PM
Removing Product Darren F Auto Detailing Forum 4 08-05-2006 10:16 AM
removing tape 98bmw323is Auto Detailing Forum 2 05-10-2006 08:11 PM
» November 2008
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
