Go Back   Auto Geek Online Auto Detailing Forum > The Water Cooler > Off-Topic
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 10-24-2012, 11:30 PM   #1
chemguy626's Avatar
Mike phillips..school me on painting
This weekend I will be painting my aunts 2001 volvo s40. The car has clear coat failure. I will be painting it a single stage metallic.
My question is about color sanding after I paint it. How long after I paint it should I wait(this will be painted in a garage) to color sand and polish it? What about sealing it afterwards? Is there any other pointers you can give me? I am excellent at the prep and im an ok painter(i took painting and refinishing in college).
Thanks for your time
Sent from my MB855 using Tapatalk 2
chemguy626 is offline
Old 10-25-2012, 02:56 AM   #2
Skimmer0220's Avatar
Check your data sheets there'll be something on there about how long it will take till you can sand
Sent from space through a satellite
Skimmer0220 is online now
Old 10-25-2012, 06:42 AM   #3
BobbyG's Avatar
Re: Mike phillips..school me on painting
If you're using lets say DuPont Centari enamel I'd advise using their DuPont 793S Acrylic Enamel Hardener.. This is a chemical hardener designed as a catalyst to chemically harden and cure the paint in 24 hours.
1 PINT 793S ACRYLIC ENAMEL HARDENER CENTARI DUPONT
http://www2.dupont.com/Coating_Solut...opcoat_A_E.pdf
DuPont Centari Enamel Application
  • Apply three full wet coats. No additional flash time is required. If a mist-coat is required for metallic colors, mist coat while coating is still wet.
  • In case of fish eyes, add up to 1 oz. of DuPont™ 259S™ Additive per RTS gallon.
  • Add up to 15% DuPont™ Centari® Topcoat mixing enamel for tinting purposes.
  • If clear-coating, allow topcoat to cure overnight before applying ChromaClear® 7900S™ Multi-Use Urethane or ChromaClear® 7779S™ Multi-Mix™ Clear coats. Follow clear coat recommendations for activation and application.
  • DuPont™ Centari® Topcoat can be clear-coated up to 48 hours after the final coat without the need to sand.
  • 77°F (25°C) & 50% Rh at recommended film thickness
  • With DuPont™ 793S™
    Tack Free 1-2 hrs
    Tape Free 4 hrs
Wet sand after 48 hours..
__________________
BobbyG is offline
Old 10-25-2012, 11:27 AM   #4
chemguy626's Avatar
what about polishing and sealing after that?
Old 10-25-2012, 11:44 AM   #5
DaveT435's Avatar
I assume you know to get as much dust out of there as you can and wet the floor to keep dust down...
DaveT435 is offline
Old 10-25-2012, 11:45 AM   #6
Director of Training
Mike.Phillips@Autogeek's Avatar
Quote:
Originally Posted by Skimmer0220 View Post
Check your data sheets there'll be something on there about how long it will take till you can sand.
Good advice.
The paint shop where you buy your paint should also be able to give you some directions for your specific geographical location too if there are any extremes in your weather/temperatures.
Quote:
Thanks Bobby for looking that up.
A good rule of thumb for most paint systems in most geographical locations is to wait for about 3 days but get on it before a week or two passes.
I have a 1965 Comet Convertible coming up to do a full wetsand cut and buff, I'll document as much of it as I can for an article.
Mike.Phillips@Autogeek is offline
Old 10-25-2012, 12:20 PM   #7
Quote:
Sanding, compounding and polishing are one process.
I would recommend using the best sanding papers you can obtain and finish out at least 2000 grit. Higher if you can get it. My personal preference is to machine dampsand but you can hand sand too..
Then have a high quality wool cutting pad and a rotary buffer and a good compound ready to cut out your sanding marks. Machine polish with foam pads and then stop until around 30 days pass.
Then seal the paint with a car wax, synthetic paint sealant or paint coating.
Pictures?
Old 10-25-2012, 12:22 PM   #8
Quote:
I've used plastic drop cloths to build a paint booth inside my garage and then use some large box fans to extract air.
Not a perfect approach but a lot of guys have done it like this and it does help to create a cleaner environment plus also keeps overspray off everything in your garage. If you don't want overspray dust on something... cover it.
Old 10-25-2012, 12:34 PM   #9
DaveT435's Avatar
Anything to keep dust out of the paint....and overspray is never any fun. Great idea!!
DaveT435 is offline
Old 10-25-2012, 02:41 PM   #10
chemguy626's Avatar
the guy from the paint store said you cant wetsand single stage metallic beacause you will disturb the metallic. Is this true? Any pointer on this? I just dont want ANY orange peel.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Roll Call - What's your real first name? Mike.Phillips@Autogeek Introduce Yourself 1101 05-23-2013 06:27 PM
Mike Phillips Weekend Boot Camp Blow Out Sale! Nick@Autogeek Discounts and Specials 60 02-04-2012 12:38 AM
Title suggestions for first e-book? Mike.Phillips@Autogeek Off-Topic 80 09-06-2011 10:12 AM
Mike Phillips - Doctor of Paint Care HealthyCivic Off-Topic 6 09-24-2010 10:38 AM
It's the person that does the wet-sanding, cutting and buffing that makes or breaks the paint job -Mike Phillips Mike.Phillips@Autogeek Wet-Sanding, Cutting & Buffing 3 09-14-2010 04:14 PM
» May 2013
» Car Care Brands
