Need to Pick up 1-2 Electric Pressure Washers(Fairly Cheap)
Off-TopicDiscuss Need to Pick up 1-2 Electric Pressure Washers(Fairly Cheap) in the The Water Cooler forums; Next weekend I have a ton of cars to wash at a car show and instead of using my hot ...
Next weekend I have a ton of cars to wash at a car show and instead of using my hot water pressure washer I was thinking about picking up an electric pressure washer and 1 for a back up. I was wanting to spend under $200 if that is even possible lol
Green force from lowes. $99 each. I have used mine with my foam cannon many times and love it. Comes with the wand that can attach to a foam cannon instantly. P.s. well have to meet up at C5Fest if you're going there. I'll be there!
Re: Need to Pick up 1-2 Electric Pressure Washers(Fairly Cheap)
Quote:
Green works?
Also could I get the fitting from a fitting supply store locally to run the goal Canon?
If its 1/4" threads or quick connect, you can get everything from lowes with it. If it already has the quick connect on the cannon, then it will connect directly to the end of the wand.
